Author Topic: lda pump head onto eco pump  (Read 2599 times)
January 26, 2007, 02:12:03 pm
Hillshy
  • 103
    • http://www.hillshy.co.uk
« on: January 26, 2007, 02:12:03 pm »
i shouldnt have any problems fitting this to my eco pump, right?
read some old posts as others have tried it too.
it's complete with the pin!
i got it from that diesel shop on ebay that's closing doors, and for the sum of £1.
  :D
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #1January 26, 2007, 02:15:49 pm
Hillshy
  • 103
« Reply #1 on: January 26, 2007, 02:15:49 pm »
Reply #2January 26, 2007, 08:46:24 pm
« Reply #2 on: January 26, 2007, 08:46:24 pm »
there is something else to do, giles mentioned it before, i didn't read into it very much, you can't just bolt it on, but you also have to remember that the ecodiesels have a smaller plunger as well.
Reply #3January 28, 2007, 02:53:47 am
Hillshy
  • 103
« Reply #3 on: January 28, 2007, 02:53:47 am »
Hi Trev0rbr,
cheers for the reply, ive been diging around on the site and found that people have swapped em over - i havent found a post that went into great detail-YET!, maybe its a simple swap - i'm sure there will be a post with some details. i will keep digging for now.
the lid is coming off later so either way i'm going to find out , i will post my results in a few days!
stu
Reply #4January 28, 2007, 02:35:42 pm
Hillshy
  • 103
« Reply #4 on: January 28, 2007, 02:35:42 pm »
Hi all,
hi libbybapa, i just finished the swap over and reading all the prev posts that relate to the Gov mods and general pump stripping, i can say they really helped and i can see why people have problems with the settings afterwards, but i remembered to mark everything so it went ok, the throttle springs were for me the hardest to reinstall.
the swap out, lucky enough i have a genuine lda pump to use as reference
so i popped the lid off that first and studied it for a while and then popped the lid off the eco pump and found no differences between the two, so i knew the lda head would mate up to the eco pump, i stripped the parts off the eco head and reasembled it, all seemed rather straight forward.
the pump going to need setting up/tuning and when i compaired the spring tention(pin/plunger) on the eco pump head now lda with the lda of the geniune td pump they were totally opposite ends of the scale, otherwise it seems fine, i tried to make all the other setting as i found them before the swap, i.e throttle stop position and so on.
eco before
eco during
now lda
both
so feeling happy now, productive few hours for once. :D  :D
