Author Topic: where do i get timing tools  (Read 5253 times)
January 10, 2007, 11:18:58 am
craiggroombridge
  • 38
« on: January 10, 2007, 11:18:58 am »
Looking for pump timing tools and other stuff needed for working on n/a and turbo d's
Please help thanks
Craig
My first was an 85 gas fun
my second is an 86 gas more fun
my third is a 92 n/a diesel project
Reply #1January 10, 2007, 11:45:15 am
« Reply #1 on: January 10, 2007, 11:45:15 am »
Reply #2January 10, 2007, 12:04:03 pm
craiggroombridge
  • 38
« Reply #2 on: January 10, 2007, 12:04:03 pm »
sweet thanks burn
Reply #3January 10, 2007, 12:18:53 pm
« Reply #3 on: January 10, 2007, 12:18:53 pm »
not a problem
Reply #4January 10, 2007, 10:37:54 pm
duffer
  • 164
« Reply #4 on: January 10, 2007, 10:37:54 pm »
Also  skywaytools.com
Reply #5January 11, 2007, 03:36:56 am
Ziptar
  • 565
« Reply #5 on: January 11, 2007, 03:36:56 am »
http://www.metalnerd.com/
Also good! I borrowed a set years back to do the TB on my 98 TDI. Well made and worked great.
Reply #6January 11, 2007, 08:27:15 am
craiggroombridge
  • 38
« Reply #6 on: January 11, 2007, 08:27:15 am »
Great  :!: now I can start to better my n/a drivability also the bently is on the way ..
Thank you all Craig
Reply #7January 13, 2007, 01:36:09 pm
Turbinepowered
  • 1206
« Reply #7 on: January 13, 2007, 01:36:09 pm »
Quick question regarding the eMiata toolset; what's the scale on the dial indicator?
Goes from 0-100 clockwise, small dial in the face from 0-10 clockwise, and the two sets of numbers on the face are "->| |<- .001 in" and "0-1.0 in".
I'm assuming this means that each individual tick mark on the big dial is .001" as the distance between the vertical lines is about the same as the distance of the arc between individual marks, but what's the small dial for?
Just seems a bit strange, all the timing measurements I've seen are given in mm and the recommended vendor's gauge is in inches.
Reply #8January 13, 2007, 03:05:24 pm
craiggroombridge
  • 38
« Reply #8 on: January 13, 2007, 03:05:24 pm »
the small one is in .100 of an inch if it is not metric the big face is of corse .001 graduations, there are timing setups in imperail mesure.
Personly I think non metric is more accurate, this is my opinion I could be WRONG
Craig
Reply #9January 13, 2007, 03:21:03 pm
Turbinepowered
  • 1206
« Reply #9 on: January 13, 2007, 03:21:03 pm »
Quote from: "craiggroombridge"
That's what I've been slowly, slowly coming to realize, the purpose of the two faces.
And I can convert the mm measurements to inch measurements fairly handily enough; excellent.
My thanks!
Reply #10January 14, 2007, 04:53:38 am
craiggroombridge
  • 38
« Reply #10 on: January 14, 2007, 04:53:38 am »
some older mittchell manuals show the timing setup in imperail, ceria 1986, trying to get that book. no luck so far
