Author Topic: Injector Lines Leaking.... (Ground ? as well)  (Read 2914 times)
January 05, 2007, 10:32:29 am
Donny
  • 14
« on: January 05, 2007, 10:32:29 am »
I have a 1.6l N/A. Here is the issue:
My hard Injector lines are leaking. I had originally thought it was the rubber ones but that is not the case. So my question is, how much am I gonna pya for them, and where can I get them at a decent price?
I also want to know if there is a ground wire upgrade kit for these cars.
Reply #1January 05, 2007, 11:35:56 am
« Reply #1 on: January 05, 2007, 11:35:56 am »
sometimes you can get away with just tightening them a bit... don't go nuts on them... happened to me in the summer time.  the injector lines were a bit 'moist' and hot starting was a pain...
Reply #2January 05, 2007, 11:52:48 am
g-spec
  • 289
« Reply #2 on: January 05, 2007, 11:52:48 am »
I a problem with injection lines leaking after i reinstalled them....a drop of oil helps!!!
Reply #3January 06, 2007, 03:20:36 am
Donny
  • 14
« Reply #3 on: January 06, 2007, 03:20:36 am »
They aren't leaking at the fasteners. They are leaking on the main part of the line so I just wanna get em all replaced and get this thing on the road safely.
So a rough estimate of what they cost is appreciated.
Reply #4January 06, 2007, 04:52:31 am
« Reply #4 on: January 06, 2007, 04:52:31 am »
yea if the actual line is starting to leak.. dont drive it.  there is some crazy pressures in those lines!!!
Reply #5January 06, 2007, 06:47:08 am
QuickTD
  • 1156
« Reply #5 on: January 06, 2007, 06:47:08 am »
Get used injection lines, someone here will sell you a set. New ones are insane.
As for the ground wire, there is only one from battery to block, replace it with 1 awg welding cable. There are no "grounding kits" for old diesels because there aren't any electronics on the engine, so no improvements to be had.
Reply #6January 06, 2007, 09:15:59 am
g-spec
  • 289
« Reply #6 on: January 06, 2007, 09:15:59 am »
I have a set from my 1.9TD. I can sell them to you...send me a IM
Reply #7January 06, 2007, 10:21:56 am
Donny
  • 14
« Reply #7 on: January 06, 2007, 10:21:56 am »
will those work in my car seeing as it is a 1.6l n/a?
