Author Topic: cam position  (Read 2920 times)
December 16, 2006, 08:56:23 pm
pariah
  • 31
cam position
« on: December 16, 2006, 08:56:23 pm »
so my bently said in regards to TDC with the cam pully that i should take the valve cover off and the # 1 lobes should be apoximately pointing up... im cool with that but there is like 3 or 4 teeth play on the timing belt where the lobes are not engaging ..... there seems to be no mark on the pully call it good? help :) :?:
Reply #1December 16, 2006, 09:04:31 pm
Kudagra
  • 738
    • www.no-coast.com
Re: cam position
« Reply #1 on: December 16, 2006, 09:04:31 pm »
Ya ever look up timing tools on Ebay...there is a little flat peice of metal. That fits in the slot on the back of the cam and keeps it level with the gasket sealing surface. Get that slot pretty level with the lobes up and you should be in the area you want. But its best to be acurate..so make one of those tools.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #2December 16, 2006, 09:05:05 pm
cam position
« Reply #2 on: December 16, 2006, 09:05:05 pm »
on the opposite end of the camshaft there is a place for a key.  did you buy a timing kit?  i guess you could shim some pieces of something in there to 'lock' the cam, but its best if you buy one of those kits off ebay or whatever.  the kit I bought had this seriously tight cam locking tool... needed a hammer to install it and remove it!!!  (tighter is better  :lol: )
Reply #3December 16, 2006, 09:26:35 pm
Turbinepowered
  • 1206
cam position
« Reply #3 on: December 16, 2006, 09:26:35 pm »
Quote from: "jtanguay"
In the words of a relative of mine: "If it's tight, it's right."  :D
Reply #4December 17, 2006, 06:42:06 am
pariah
  • 31
thnks
« Reply #4 on: December 17, 2006, 06:42:06 am »
hey thanks i feel like an idot somtimes but i really appreciate you guys helping
Reply #5December 17, 2006, 09:45:54 pm
timing tools
« Reply #5 on: December 17, 2006, 09:45:54 pm »
I bought my IP timing tools from this place. They had better prices than anything I saw on e-bay  http://www.emiata.com/DieselVW/
I already had the cam tool, IP pin, belt tool and belt tension gauge, so I
didn't get any of them, but they have a great price in the whole kit for
$79. Well, they don't sell the belt tension gauge, but everything else.
Reply #6December 17, 2006, 11:30:05 pm
cam position
« Reply #6 on: December 17, 2006, 11:30:05 pm »
I never use timing tools, only the guage. I line the cam up by eye and use a deep socket to hold the IP roughly in place. I just make sure that when I put the belt on the pulley that it's perfectly lined up. 3 timing belt changes so far without a problem.
The only tool that I want is the tension gauge
