1.9aaz v.s. 1.6td injectors.
Topic: 1.9aaz v.s. 1.6td injectors. (Read 12775 times)
December 14, 2006, 02:04:43 pm
foxracer1
Authorized Vendor
December 14, 2006, 02:04:43 pm »
Are there any differences in these? Better worse? What about TD nozzles in an N/A?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
December 14, 2006, 03:24:51 pm
December 14, 2006, 03:24:51 pm »
1.6 Td injectors have a higher breaking pressure (150 psi I think) compared to NA injectors. You have to fiddle with the timing to use 1,6TDs on a NA
January 10, 2007, 07:28:07 am
DieselSteed
January 10, 2007, 07:28:07 am »
I was also wondering about the difference between these injectors. I am running the 1.6 TD pump and injectors on my 1.9 TD AAZ. Can the AAZ injectors (028 130201 B) be used with the 1.6 IP?
When my lady really wants to get me in the mood, she rubs a little diesel behind her ears.
January 10, 2007, 03:25:39 pm
January 10, 2007, 03:25:39 pm »
yes
January 10, 2007, 04:46:23 pm
sethyboy85
January 10, 2007, 04:46:23 pm »
1.6NA= 130bar, 1.6TD =155bar
Just clarifying so the yungies don't get confused.
NA34X mercedes benz Turbo injectors are 155bar as well and flow more fuel than the "upgraded" 1.6TD injectors that have GTD nozzles...
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
January 10, 2007, 05:22:41 pm
DieselSteed
January 10, 2007, 05:22:41 pm »
Thanks for the replies. Was just wondering if that part number was one of those AAZ two stage injectors. Interesting information about the Mercedes injectors. Always interested to know how to get more fuel into the cylinders.
January 10, 2007, 05:59:41 pm
January 10, 2007, 05:59:41 pm »
i'm not sure but i know you could also try vanagon or quantum nozzles, they are supposed to flow more than stock as well
January 10, 2007, 06:26:28 pm
foxracer1
Authorized Vendor
January 10, 2007, 06:26:28 pm »
What model mercedes are those injectors from? Wheres the best place to get them? Thanks for the good info.
91 S10 305 TPI T56
January 11, 2007, 04:19:18 pm
sethyboy85
January 11, 2007, 04:19:18 pm »
any 80's 5cyl Turbo Diesel
http://www.autohausaz.com/search/product.aspx?sid=yteeorzcgmhcoo552d0kui55&makeid=800016@Mercedes&modelid=1194049@300SD&year=1985&cid=22@Fuel%20%26%20Air%20System&gid=6100@Diesel%20Injector
January 11, 2007, 06:05:38 pm
DieselSteed
January 11, 2007, 06:05:38 pm »
Thanks Sethyboy85. Limited quanities on hand huh? then soon have none lol: I have been buying my parts from AutohausAZ for a long time now. Their heat shields are about 85 cent each. They really do have the best prices.
January 11, 2007, 08:05:55 pm
sethyboy85
January 11, 2007, 08:05:55 pm »
Oh yeah they are slightly shorter but it's nothing the injector lines can't handle after you take off the brace that holds them all together then put it back on after installing the lines.
Reply #11
January 12, 2007, 06:32:14 am
DieselSteed
Reply #11 on:
January 12, 2007, 06:32:14 am »
Then they might be a perfect fit for an AAZ using 1.6 TD lines and IP. I had to remove the clamps and bend mine up slight (#3 & #4 mainly) to make them work. I am a little worried about the lines being stressed. Thanks for that last tidbit of info. I have a new plan :twisted:
Reply #12
January 13, 2007, 02:49:45 pm
foxracer1
Authorized Vendor
Reply #12 on:
January 13, 2007, 02:49:45 pm »
Where can i find just replacement nozzles for these? I can get the injectors from 2 audi 5cyl diesels and i know they will need to be rebuilt.
91 S10 305 TPI T56
Reply #13
January 13, 2007, 09:20:23 pm
hillfolk'r
Reply #13 on:
January 13, 2007, 09:20:23 pm »
try not to bend lines ,its not a good idea...
the(zinc?) plating can fracture on the inside of the lines when you bend them,and over time that junk gets sent into your injectors....
repeat after me: I will never bend hi pressure diesel fuel injector lines :wink:
Throttle cables ftw
Reply #14
January 13, 2007, 09:25:15 pm
sethyboy85
Reply #14 on:
January 13, 2007, 09:25:15 pm »
thats why you have to take the brace off and install one injector line at a time to get the angle correct then reinstall brace.
