Author Topic: 1.9aaz v.s. 1.6td injectors.  (Read 12740 times)
Reply #15January 14, 2007, 12:08:39 am
Lil' Stinker
  • 5
    • http://www.myspace.com/davidshuman
« Reply #15 on: January 14, 2007, 12:08:39 am »
Hi,
Just to clarify, are the NA34X injectors complete and ready to bolt in or do you also need to get the Balo injector nozzles as well that are on the page?
1983 Rabbit Turbo Diesel GL
The Lil' Stinker
Reply #16January 14, 2007, 06:05:43 am
sethyboy85
  • 284
« Reply #16 on: January 14, 2007, 06:05:43 am »
They drop in, Injector only needed.
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #17January 14, 2007, 10:55:17 am
DieselSteed
  • 107
« Reply #17 on: January 14, 2007, 10:55:17 am »
Quote from: Sethytboy85
They drop in, Injector only needed..
Do new Vw heat shields need to be installed also? I'll be getting new lines when I get these injectors and I'll tighten them down like you said.
Quote from: hillfolk'r
repeat after me: I will never bend hi pressure diesel fuel injector lines.
I really didnt want to do it. I did use a tubeing bender though. It was the only way I could use the 1.6td hardware on the AAZ. Is there another route I could have taken?
When my lady really wants to get me in the mood, she rubs a little diesel behind her ears.
Reply #18January 14, 2007, 02:20:55 pm
Lil' Stinker
  • 5
« Reply #18 on: January 14, 2007, 02:20:55 pm »
I just ordered the mercedes injectors and the vw heat shields from autohaus.
The Lil' Stinker
Reply #19January 14, 2007, 04:28:59 pm
sethyboy85
  • 284
« Reply #19 on: January 14, 2007, 04:28:59 pm »
Yes, alsway install new heat shields whenever you take out your injectors.
My oh my we are going to have alot of people running around with NA34X in their cars soon.
Reply #20January 15, 2007, 03:01:00 pm
Lil' Stinker
  • 5
« Reply #20 on: January 15, 2007, 03:01:00 pm »
bad news, autohaus called and left me a message, evidentally the mercedes injectors are on indefinite back order with no indication if and when more wil arrive.  I find it hard to believe that all those mercedes turbo diesels are out of luck.  Anyone have any other suggestions?
The Lil' Stinker
Reply #21January 15, 2007, 04:35:08 pm
sethyboy85
  • 284
« Reply #21 on: January 15, 2007, 04:35:08 pm »
PM if you seriously want a set, I can get them. 155bar NA34X rebuilt to OEM
Reply #22January 18, 2007, 10:13:31 am
foxracer1
  • 991
« Reply #22 on: January 18, 2007, 10:13:31 am »
Yeah im interested. How much for a set?
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #23January 25, 2007, 05:25:36 pm
lacolocho
  • 80
discount
« Reply #23 on: January 25, 2007, 05:25:36 pm »
Discount Import Parts in Portland has everything. I think they have Mercedes injectors for about $50 each.
http://www.discountimportparts.com/
Reply #24January 25, 2007, 06:19:17 pm
lacolocho
  • 80
also
« Reply #24 on: January 25, 2007, 06:19:17 pm »
In seattle, $75 each for rebuilt Mercedes injectors w/ GTD nozzles:
dieselhead.net
Reply #25January 26, 2007, 06:01:44 pm
lacolocho
  • 80
so...
« Reply #25 on: January 26, 2007, 06:01:44 pm »
Discount Import Parts has the same ones in stock for $42 each.
Do the Mercedes injectors result in increased fuel consumption? Do you still use the VW heat shields? Will they even give you the core price back for returning them VW injectors instead of Mercedes ones? (though they probably wouldn't notice)
Reply #26January 27, 2007, 06:39:09 pm
sethyboy85
  • 284
« Reply #26 on: January 27, 2007, 06:39:09 pm »
Depends on your foot, Yes. don't know about that one but I am sure it would catch up to you for returning VW instead of Mercedes. just find some from a JY that are at least mercedes maybe not 155bar but still better than a totaly wrong injector.
Reply #27January 27, 2007, 11:19:47 pm
foxracer1
  • 991
« Reply #27 on: January 27, 2007, 11:19:47 pm »
dieselhead.net
Wouldn't this make the injector just like the VW injector? You would lose the added flow from the Merc inj. Just a thought. :?: [/url]
91 S10 305 TPI T56
Reply #28January 29, 2007, 04:23:11 pm
lacolocho
  • 80
so, yes
« Reply #28 on: January 29, 2007, 04:23:11 pm »
How much of a drop in mpg can one expect with the mercedes injectors?
How much more power can be expected?
