Author Topic: performance of a 1.9td head on a 1.6td  (Read 2860 times)
December 08, 2006, 07:47:32 pm
84Q
« on: December 08, 2006, 07:47:32 pm »
how much performance will putting a stock 1.9td head on a 1.6td add? and how about the cons? the engine will eventually be running many other mods as cash slowly drips down to me. such as new cam, exhaust, pump, nozzles, etc.
thanks
Reply #1December 09, 2006, 04:09:06 am
Benjamin
  • 485
« Reply #1 on: December 09, 2006, 04:09:06 am »
as long as you run 100% stock settings, you will not have no any hp, maybe the turbo spools up a little faster.
if you gonna tune the pump and planning a bigger turbo, i advise you to put that 1.9 head on your 1.6 block  :wink:
Greetz, Benjamin
SMOG alert, engine running again!
Must make +250hp
Reply #2December 09, 2006, 07:35:32 am
SMOKEYDUB
  • 630
« Reply #2 on: December 09, 2006, 07:35:32 am »
well you may want to read up on a couple of old posts on this site about that before you do it. I think malone has done a thread on it and crissev? Try searching for franken engine
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #3December 09, 2006, 08:24:10 am
« Reply #3 on: December 09, 2006, 08:24:10 am »
in a nutshell, putting a 1.9 head on a 1.6 block gives better airflow, but lowers cr so you get rougher cold starts.
better airflow is the basis for more power, but to achieve more power you need more fuel.  more air allows you to run more fuel :)
Reply #4December 09, 2006, 12:37:50 pm
  • 5104
« Reply #4 on: December 09, 2006, 12:37:50 pm »
and fuel is everything on these cars. everything!
Reply #5December 09, 2006, 08:33:10 pm
SMOKEYDUB
  • 630
« Reply #5 on: December 09, 2006, 08:33:10 pm »
so is crazy boost :D  with fuel you need boost or melt some pistons out but yes fuel is a huge part of performance.
(courtesy of GILES)
