Author Topic: intake on na diesel? mrsharkey?  (Read 4190 times)
December 05, 2006, 08:48:56 pm
foxracer1
  • Authorized Vendor
  • 991
« on: December 05, 2006, 08:48:56 pm »
I'm interested in some sort of intake for my na any body have any sugg.? I recall mrsharkeys intake for his EV pusher where the intake did a 180 and pulled air from the rain tray area.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #1December 06, 2006, 08:19:49 am
monst
  • 184
« Reply #1 on: December 06, 2006, 08:19:49 am »
I would be interested in this too...
I have been meaning to do something with
the intake on the na....
The raintray with give really good flow...
it is just the water...... how to solve that
issue..... I am thinking about making something
out of aluminum.... like thin... that is bent on
a carpenters break.... to form a piece of duct work.......
this could say be bolted or screwed on...
Jetta A2 91 1.6L Naturally Asthmatic....
Bosal header 2.25" exhaust Flomaster
Reply #2December 06, 2006, 09:17:01 am
RabbitGTDguy
  • 1274
« Reply #2 on: December 06, 2006, 09:17:01 am »
I haven't seen Sharkey post in a LONG LONG time... wish he was around :)
There are a variety of ways to do it. If you look, I believe Roger Brown's "Caddyshack" site has what he did for a "ram air" style intake with fairly little cost in materials at all. Good stuff... its the 4crawler website I believe. Maybe he'll chime in.
Joe
1972 VW Westfalia
2001 Audi TT 225 Quattro Roadster (something newer :) )
Reply #3December 06, 2006, 02:22:02 pm
  • 5104
« Reply #3 on: December 06, 2006, 02:22:02 pm »
imo the n/a intake is pretty nice it just needs a much larger snorkel since it was designed to make the engine quieter instead of making it more powerful, i would either put a mk2 n/a intake on or just put a much larger snorkel on whats already there
Reply #4December 06, 2006, 03:18:13 pm
« Reply #4 on: December 06, 2006, 03:18:13 pm »
Wasn't there a post about this 2 months back? and piles of people posted up their custom intakes?
... I'll try a search
et voila
http://vwdiesel.net/phpBB/viewtopic.php?t=5427&highlight=ram+air
Reply #5December 06, 2006, 08:24:19 pm
foxracer1
  • Authorized Vendor
  • 991
« Reply #5 on: December 06, 2006, 08:24:19 pm »
Well i like the idea of going up front to get cold air. But not with the factory snorkel. I cut a hole in an airbox lid i had layin around i'm in the process of makin one like mrsharkeys. But any how my EGTs dropped quite a bit all around with the elimination of the factory snorkel. Yes its louder but after i make the rest of the intake i will see what it sounds like. heres sharkeys wesite. scroll about 1/2 way down to see the intake picture.
www.mrsharkey.com/lpg.htm
91 S10 305 TPI T56
Reply #6December 07, 2006, 06:22:04 am
monst
  • 184
« Reply #6 on: December 07, 2006, 06:22:04 am »
Yeah, Sharkey's
Idea is cool...... I guess it is under the tray
so it gets no water.....
Yeah, Keep us posted on how loud it is...
looks like he used rubber ferno 90s and
some 3" abs pipe and a maybe a 22 degree
bend into the firewall. 8)
Reply #7December 07, 2006, 09:30:17 pm
VWCaddy
  • 85
    • VW Caddy Page
« Reply #7 on: December 07, 2006, 09:30:17 pm »
Here is mine:
- http://www.4crawler.com/Diesel/CheapTricks/index.shtml#ColdAirIntake
Easy on/off with one screw and it seems to work fine, can feel the difference off the line on hot days.
'82 VW pickup, 1.9D engine, Missing LinkZ shift linkage
Reply #8December 08, 2006, 03:03:19 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #8 on: December 08, 2006, 03:03:19 am »
here ya go....
this is on my 1.5 n/a. its all 80mm PVC, cheap easy, reliable, quick sefl supporting.... etc etc
really, this works incredibly well
'91 Golf Cabrio 1.9TD
Reply #9December 08, 2006, 03:09:35 am
gldgti
  • 488
« Reply #9 on: December 08, 2006, 03:09:35 am »
dont be scared to cut out the original hole in the airbox.... i used some steel sheet and bent up a new pipe to take the 80mm pvc, simply riveted into the plastic and sealed with silicone (then painted over).
also, on/off with one screw. at hte front, the pipe which appears to go into the side of the rediator does face that way, but is cut at 45deg to make a large opening that gets air from the front, and infront of the radiator.
cheers
aydan
Reply #10December 08, 2006, 03:13:16 am
gldgti
  • 488
« Reply #10 on: December 08, 2006, 03:13:16 am »
oh and noise....
at the moment, mine is quite loud and growly (actually quite mean sounding) at about 3000-3500rpm. if i take OFF the last 90 deg bent that gets it to the very front, i get no induction noise at all. no pipe and i get a nice loud drone all the way through the rev range  :P
Reply #11December 08, 2006, 05:41:09 pm
Otis2
  • 191
« Reply #11 on: December 08, 2006, 05:41:09 pm »
Quote from: "RabbitGTDguy"
He's been busy being a TV star.  I caught him on the idiot box the other night.
Check out episode 2 of "Cool Fuel Roadtrip".  (All but unwatchable series... hosted by an obnoxious Aussie who really needs to get stung by a ray IMHO).
http://www.coolfuelroadtrip.com
