Author Topic: Non-turbo Eco-diesel: Turbo ready?  (Read 8719 times)
October 22, 2004, 10:37:40 am
vwrabbit
  • 9
« on: October 22, 2004, 10:37:40 am »
I'm interested in a 1991 Jetta NA Diesel that has the ME (Mexico) code diesel engine and he claims it's an eco-diesel.  I thought all ecos were turboed.  Is this eco turbo ready?  I.E. have the same head, pistons, oil squirters and the turboed version?
Thanks,
Tim
Reply #1October 22, 2004, 10:45:12 am
vwrabbit
  • 9
« Reply #1 on: October 22, 2004, 10:45:12 am »
I found that the 1V is eco, ME is normally aspirated.  I don't suppose these still used the better heads and oil squirters?  :)
Reply #2October 28, 2004, 06:21:15 pm
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #2 on: October 28, 2004, 06:21:15 pm »
Without looking im my Bentley, I'd say the CR (compression ratio) would be too high, as when you go from NA (normally aspirated) to forced induction using either a turbo or a supercharger, such as a G-Lader, you need to reduce the compression ratio.
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #3October 29, 2004, 10:21:45 am
Dr. Diesel
  • 1341
« Reply #3 on: October 29, 2004, 10:21:45 am »
As far as i know, true eco diesels all came with turbochargers. That's what made them "eco", getting extra air to run cleaner. If it really is an eco, then someone must have removed the turbo at some point. Should be good to go for re-turbo-ing.
Reply #4October 29, 2004, 10:54:01 am
fspGTD
  • 1529
« Reply #4 on: October 29, 2004, 10:54:01 am »
Quote from: "GTD."
Sure, on a gas engine, you'd need to do take measures such as reducing CR when going to forced induction in order to keep detonation at bay.  But on a diesel (including VW's diesel models) they don't, and it is not necessary, because detonation isn't possible on a diesel motor.
Jake Russell
Reply #5October 29, 2004, 11:00:10 am
fspGTD
  • 1529
« Reply #5 on: October 29, 2004, 11:00:10 am »
Quote from: "Dr. Diesel"
According to ETKA: the '91-'92 Jetta "eco diesel", Engine code "1V", indeed has a small turbocharger, although no boost enrichment device.  I'm fairly certain that piston-cooling oil jets are found in all VW turbo diesel motors including the "1V".
Jake Russell
Reply #6October 31, 2004, 12:33:56 am
quantumsyncro
  • 3
« Reply #6 on: October 31, 2004, 12:33:56 am »
If it's ME then it's not ECOdiesel. Also, prior post is correct, the ECOd did have a smaller turbo but no boost enrichment on the inj. pump. The confusion comes because VW at this time was producing the 1.6D (me), the 1.6TD (mf) and the 1.6 ECOd (1v).
There's often a lot of confusion about this, people list ECOd's as TD's, which technically is accurate, but not generally what we want when were really looking for the 1.6 MF engine.
It's also often something that you cant get to the bottom of until you see it for yourself. At least that's been my experience!
good luck
steve a
1997 JIII TDI
1986 GII D
Reply #7October 31, 2004, 02:17:18 pm
fspGTD
  • 1529
« Reply #7 on: October 31, 2004, 02:17:18 pm »
I don't think I've never found evidence of a diesel '91-'92 Jetta sold in the US that didn't have the "1V" eco diesel engine.
I also haven't heard of an A2 diesel Golf that didn't have the naturally aspirated 1.6l diesel (ME), or an '85-'86 diesel Jetta that wasn't an "MF".
I'm pretty sure this could be confirmed in ETKA, but I haven't done so... just going off of memory here.  Please correct me if I am wrong.
Anyway, in summary, all you need to know to figure out which A2 diesel it is, if sold in the US market, is the year and the model.
Jake Russell
Reply #8December 07, 2004, 02:46:54 pm
shakakan
  • 20
my 91 is NA
« Reply #8 on: December 07, 2004, 02:46:54 pm »
my 91 jetta is NA...  Unless someone before me took the turbo off, which I doubt.  It does have the ATM comp pump on it.
Reply #9December 12, 2004, 02:40:57 pm
dieselpower
  • 177
« Reply #9 on: December 12, 2004, 02:40:57 pm »
hey,
my dads old 91 jetta was a turbo diesel, code "MF" i think.
Mark
84 rabbit 1.6TD
because real cars don't have sparkplugs
Reply #10January 23, 2005, 06:59:17 am
mainer
  • 126
« Reply #10 on: January 23, 2005, 06:59:17 am »
my 91 jetta is an eco diesel....
my friends 91 jetta is n/a diesel
there was only 750 eco diesels ever made in the us for 1991
and only 47 eco diesels made in 1992
if anyone on hear has an eco diesel there is an eco diesel specific web site with a bunch of background info on them.
mines still running great with 261,000 miles on it... original everything, clutch and all.
_________________
Ferrari 212 Export
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
