Author Topic: B3 Passat RPM's at speed?  (Read 5242 times)
November 12, 2006, 03:45:27 pm
commuter boy
  • 277
« on: November 12, 2006, 03:45:27 pm »
I've never been impressed with the mileage or the cabin noise in my B3 Passat, and I'm beginning to wonder if I've got a different 5th gear in it.
What RPM does someone else's Passat run at speed?  Mine's 3,000 rpm at 110 km/hr (68mph) in 5th.
Reply #1November 12, 2006, 08:45:42 pm
« Reply #1 on: November 12, 2006, 08:45:42 pm »
I just bought a CHE tranny :)
Final          1st            2nd           3rd            4th            5th
3.67          3.45   1.94   1.29   0.97   0.71
the prev owner got the taller 5th gear installed!  Eagerly awaiting its install!!!  3k rpm gives 78.0mph or 125.53 kph.  increase the tire size, and i can squeeze another 5 kph for 3k rpm :)
I havent checked.. but i swear i have the AVX in my car now... it goes like this
4.25   3.45   1.94   1.29   0.91   0.75
it barely made 64 mph at 3k rpm and so had to be driven at around 3500 do keep up with traffic...  that thing was a pig!  I'm almost sure that it was because it came with cruise control though...  All I will do is mod the car a bit and then fix up the cruise and it will work great!
Reply #2November 18, 2006, 01:32:13 pm
andy2
« Reply #2 on: November 18, 2006, 01:32:13 pm »
I just checked my dads b4 passat I think (95) AAZ and at approx 3000 rpm it runs at approx 111-113km/hr.So yours seems normal to me.I wonder if the b4 passat TDI (96) has different trans gearing thats better suited for cruising??
Reply #3November 18, 2006, 04:50:51 pm
commuter boy
  • 277
« Reply #3 on: November 18, 2006, 04:50:51 pm »
Thanks for the replies.
I'm beginning to wonder if the cabin noise is from something else then, maybe rumbly wheel bearings.
Reply #4November 18, 2006, 08:11:56 pm
« Reply #4 on: November 18, 2006, 08:11:56 pm »
My 92 jetta TD is at about 2600 at 100kmh. 3000 is 110. I'm also experiencing a grinding noise, I'm pretty sure it's my bearings. I'm still on my first tank, and I have over half left and have gone 520 kms  :)
Reply #5November 18, 2006, 10:35:05 pm
LeeG
  • 401
« Reply #5 on: November 18, 2006, 10:35:05 pm »
One problem with our cars is seperating the normal noise fom the bad.  I recently noticed how much quiter my car was after I disconected the Vbelt from the now siezed PS pump.  It was letting me know it was going for a long time, but the noises blended into the other rattles.
Your wheel bearings will get louder, but it might take a while.  It took probably 5,000 km for mine to get from the stage of 'yup that new sound goes away when in RH turns...probably bearings' To the stage of not being able to get the stereo loud enough to drown the noise and other drivers looking over at me on the highway.   And yet the bearing only had a few minor pits in one race.
'97 Passat TDI
Reply #6November 19, 2006, 11:54:41 am
anarchyx34
« Reply #6 on: November 19, 2006, 11:54:41 am »
Quote from: burn_your_money
That nice. Which trans are you running? I plan on putting an AON trans in mine.
Reply #7November 19, 2006, 08:50:26 pm
« Reply #7 on: November 19, 2006, 08:50:26 pm »
nice choice on the AON, its kinda like the CHD...
3.67   3.45   1.94   1.37   1.03   0.75
74.3mph @ 3000rpm with a wheel circle of 71.5"
there must be a way to get insane gears for these tranny's though... like a 0.65 5th lol... 85.2mph @ 3000rpm!!!  i'm sure the head gasket would really want to blow though!
Reply #8November 19, 2006, 10:40:53 pm
« Reply #8 on: November 19, 2006, 10:40:53 pm »
I'm using a 4S
