General Information
Troubleshooting
Temp guage up, no heat
Topic: Temp guage up, no heat (Read 5695 times)
November 07, 2006, 04:36:05 am
bvolks73
November 07, 2006, 04:36:05 am »
I had a strange thing happen yesterday. I was idling and the temperature guage was up about 1/4 way but only cold air was coming through the vents. I was only about a half mile from home so I figured I'd just drive it home and check it there but as soon as the car started moving again it started blowing heat again. When I got home the coolant wasn't down at all. Possibly an air lock keeping the coolant from flowing through the heater core? I've never had anything like that happen before.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
November 07, 2006, 01:57:25 pm
November 07, 2006, 01:57:25 pm »
What kind of car?
November 07, 2006, 05:06:37 pm
bvolks73
November 07, 2006, 05:06:37 pm »
:oops: Guess I should have mentioned that. 1985 Jetta NA Diesel.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
November 07, 2006, 05:14:41 pm
November 07, 2006, 05:14:41 pm »
November 07, 2006, 05:49:53 pm
November 07, 2006, 05:49:53 pm »
Loose/splitting WP belt? maybe your WP isn't pumping enough coolant?
That's a pretty strange one since it just fixed itself
November 08, 2006, 04:32:06 am
bvolks73
November 08, 2006, 04:32:06 am »
I was talking to my brother and he said he had the same problem with his Scirocco when the heater core was bad. (4c on the chart). I'm going to try to flush it out. At least I still have good heat if the rpm's are up, just not at an idle. At least it's not a big job (I put one in it already about 8 years ago).
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
November 09, 2007, 07:57:20 pm
92Wolfsburg
November 09, 2007, 07:57:20 pm »
ever end up finding the problem? The 92 wolfie is having the same symptoms....one heater core hose is hot, the other is cold...i dont get it. Nice heat at 3000rpm, none at idle...hmmm....
November 10, 2007, 06:02:50 am
bvolks73
November 10, 2007, 06:02:50 am »
If I'm not mistaken, it was the return line to the reservoir plugged. Yours sounds more like the heater core plugged though.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
November 10, 2007, 08:21:10 am
92Wolfsburg
November 10, 2007, 08:21:10 am »
Thanks for the quick reply! Yeah i flushed the heater core with a garden hose and it flowed through okay...I think I'm going to take every hose off and flush it...I kind of think that the metal line from the heater core to the pump is the culprit.
Thanks again!
General Information
Troubleshooting
