1.9td head on a 1.6td??
Topic: 1.9td head on a 1.6td?? (Read 2886 times)
October 27, 2006, 04:51:25 pm
tdi4by
User+
October 27, 2006, 04:51:25 pm »
Will a AAZ 1.9 Cylinder head bolt right on my 1.6 Hydraulic shortblock?
Is it worth it? I need a new head and figured I would upgrade for about the same cost.
1992 1.6 ECO with a TD pump. T-3 .48ar,
GTD Nozzles-I'm lovin it!!!, 47MPG mixed driving last tank.
2006 CRD Jeep Liberty with some stuff.....
Only 23MPG's..
October 27, 2006, 05:55:16 pm
October 27, 2006, 05:55:16 pm »
yes it bolts right on thurr, and do it it's a mucho upgrade
October 28, 2006, 09:13:48 am
tdi4by
User+
October 28, 2006, 09:13:48 am »
My head has never been surfaced and it is flat, but the Machine shop told me that the cracks between the valves leak into the cooling passages, it sounds like it is going to cost me around $100 per hole to weld the cracks. I just want to do a budget repair for now so is their a place to get a rebuilt head for cheaper than fixing mine? I have seen a few rebulders online like Alabama Cylinder Head and a few others that have reasonable prices...........Any input? :shock:
Only 23MPG's..
October 28, 2006, 09:16:32 am
October 28, 2006, 09:16:32 am »
Get a late mk2 head and swap all your valves etc into the new head (whatever is good anyways) Apparently the Na and TD heads are the same, only the vavles are differant. This would probably be the cheapest way to do it. Youcan rebuild your head yourself, doesn't seem too hard
http://www.hasengeeks.com/projects.php?page=cylinder_head
October 28, 2006, 09:38:40 am
tdi4by
User+
October 28, 2006, 09:38:40 am »
You can't get new castings like that for a Hydraulic head as far as I know.
Only 23MPG's..
October 28, 2006, 10:24:42 am
SMOKEYDUB
October 28, 2006, 10:24:42 am »
1.9 head is kind of for a fair weather engine. there is lots of different stories between the combos.cold starting seems to be the biggest whoooooooooor of a problem and seems to smoke alot. the 1.6 head would be the best way to go for now.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
