Author Topic: I'm back with more questions.  (Read 7567 times)
Reply #15October 15, 2006, 07:16:41 pm
mtnsammy
  • 97
« Reply #15 on: October 15, 2006, 07:16:41 pm »
Any suggestions on where to buy quality injectors? or at least the correct injectors for the 1.6TD?
Reply #16October 15, 2006, 09:39:20 pm
coke
  • 254
« Reply #16 on: October 15, 2006, 09:39:20 pm »
NA injectors are 130 bar, TD injectors are 150 bar. White smoke means timing is retarded. Advance it a few degrees and see if that clears up the smoke problem.
Reply #17October 16, 2006, 08:35:22 am
mtnsammy
  • 97
« Reply #17 on: October 16, 2006, 08:35:22 am »
Advancing is moving IP closer to motor right? Putting the gauge back on pump end will be a little difficult without removing a lot of stuff. I set the pump to about 1.02mm. It was difficult to get an accurate reading with the hose in the way. I checked it 3 times and came up with the same reading so I am pretty sure it was right. Reading numbers thru the mirror takes practice. I am assuming advanced is closer to 1.05mm and retarded is closer to .095mm.
Reply #18October 16, 2006, 06:47:35 pm
mtnsammy
  • 97
« Reply #18 on: October 16, 2006, 06:47:35 pm »
Well, a friend came over and helped with the motor. He said he new how to adjust the IP. Not. After turning the power screw several turns in both directions and then turning the smoke adjuster in till the lock nut came off I realized I am in big trouble. The motor ran before the rebuild and while the machine shop continued to cut and recut the heads. Now the IP is out of adjustment and I have no idea how to get back to stock settings.
I think the problem was mostly in the injectors, but coke had a good idea. The timing might still be off. Either the timing was retarded or I am? When I first advanced the timing the engine knocked real bad. It sounded like I was throwing a rod. If I retarded the timing more it ran rough but no knocking. I did mark the point where the timing was at 1.02 mm and moved it back and forth from there.
Does anyone have the specs for setting the IP back to stock for the powere screw and smoke screw??
