Author Topic: How Hot does your car get pulling long steep hills?  (Read 5089 times)
September 25, 2006, 03:53:04 pm
Bludodger
  • 48
« on: September 25, 2006, 03:53:04 pm »
Knowing that guages are different for each car, I was curious to ask...
On flat stretches on the Highway the car runs at midway on the guage. However with NO A/C on, when pulling up long hills in Upstate NY (elevation 1272- / I-84)  the car seemed to be approaching 4/4 on the guage  but never overheating. The car would return to 1/2- 3/4 once started down the hill. Just curious. Does this sound normal/ familiar?
Reply #1September 25, 2006, 04:05:52 pm
« Reply #1 on: September 25, 2006, 04:05:52 pm »
Mine never gets that hot, but I don't really have any logng steep hills, there's long ones, and steep ones, but not both together
Reply #2September 25, 2006, 05:14:32 pm
bvolks73
  • 183
« Reply #2 on: September 25, 2006, 05:14:32 pm »
Even on the hardest hills (had to shift down into fourth a couple times) on a 300 mile road trip a few weeks ago my guage never got above half way. Did around 140 km/h for most of it and never got hot.
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #3September 25, 2006, 10:26:03 pm
LeeG
  • 401
« Reply #3 on: September 25, 2006, 10:26:03 pm »
straight up and down most of the time, even when beating on it.  almost one notch higher happens if going slowly up a hill in traffic, same hill wound out in 3rd @ 100kmh all the way = straight up and down.
'97 Passat TDI
Reply #4September 26, 2006, 08:10:34 am
« Reply #4 on: September 26, 2006, 08:10:34 am »
I'd recommend that you hookup a digital gauge somewhere around the radiator or wherever the coolant will pass.  Maybe the steep incline is creating a blockage for coolant to pass???  4/4 is pretty hot... I'd imagine in the range of 110C  :shock:
If your coolant is that hot, just imagine how hot the head must be... Pocket of air getting trapped somewhere in the motor...  Maybe you should do a bleed of the system with the expansion tank cap off. get the air out
and btw, is your coolant level at max?
Reply #5September 27, 2006, 02:13:46 pm
« Reply #5 on: September 27, 2006, 02:13:46 pm »
forgot to mention.  If you hookup a nice thermometer to your rad, go on a hill that makes your temp climb.  If the thermometer stays low and your gauge reads high, there could be a blockage.  (the rad should read around 80-90C.  If it does go higher, your fan might not have the high speed switch)
Troubleshooting tips:
Fan operating temps:
