Author Topic: Fuel line size??  (Read 4775 times)
September 01, 2006, 06:33:36 pm
VW Scully
  • 245
    • Not Quite Tom Riddle's Diary
Fuel line size??
« on: September 01, 2006, 06:33:36 pm »
Help! My Rabbit has finally developed the dreaded "biodiesel eaten fuel line leak" on the Injector spillover lines so now I have to replace them ASAP.  :shock:
However, I don't know what size they are!!  :oops:
Can anyone tell me the diameter of the fuel lines of a 1981 Rabbit diesel!??
Thanks! :D
here's a pic; it's *these* lines
Tara aka VW Scully
**1981 Rabbit Diesel L, Biodiesel driven: 'the Bio-Bunny' **
Advocate for Young Adult Cancer Research & Support: I'm too Young for This!!
http://www.i2y.com
Reply #1September 01, 2006, 11:32:12 pm
MacGyver
  • 245
Fuel line size??
« Reply #1 on: September 01, 2006, 11:32:12 pm »
I believe it's 3mm, but 1/8" works fine as the returns shouldn't be under pressure if everything's working ok.
I'll bring you some Tygon line on Mon which will work but won't last forever either. It was cheap, I have it in stock, and it'll keep you going for now :)
Plus it's yellow clear & looks cool :P
Reply #2September 02, 2006, 08:25:27 am
VW Scully
  • 245
Fuel line size??
« Reply #2 on: September 02, 2006, 08:25:27 am »
From the responses I got on the Biodiesel BBS and the Vortex, I believe they are 3.5mm, but Robert! THANK YOU!! I just can't seem to find this size anywhere right now and need a synthetic line anyway!
plus; yellow is cool  :lol:
That will give me time to order the Biodiesel compatible ones online :).
Thanks and see ya then!
Tara aka VW Scully
http://www.i2y.com
Reply #3September 02, 2006, 08:30:10 am
QuickTD
  • 1156
Fuel line size??
« Reply #3 on: September 02, 2006, 08:30:10 am »
1/4" OD nylon air brake line also works well, and is resistant to everthing. Ideal Supply in Stratford would keep it, available in colours as well...
Reply #4September 02, 2006, 01:37:55 pm
commuter boy
  • 277
Fuel line size??
« Reply #4 on: September 02, 2006, 01:37:55 pm »
All sorts of stuff will work with Bio for a short time, but it's a real pain in the tuckus replacing them after diesel's spraying around the engine compartment and leaving puddles everywhere you sit.
Order up some Viton lines in the right size and never look back.  Greaseworks in Corvalis sells kits all ready to go, including a stubby stopper for the last injector hole.
Reply #5September 03, 2006, 06:24:02 pm
VW Scully
  • 245
Fuel line size??
« Reply #5 on: September 03, 2006, 06:24:02 pm »
Quote from: commuter boy
*edit
Commuter boy;
That is exactly what I'm going to do :D.
Problem is; I should have done that a long time ago! :oops:
Thanks!
Tara aka VW Scully
http://www.i2y.com
Reply #6September 04, 2006, 04:04:17 am
Patrick
  • 1034
Fuel line size??
« Reply #6 on: September 04, 2006, 04:04:17 am »
Quote from: QuickTD
Only problem I had with this is the nipple onthe intake that feeds the aneroid valve (LDA?) Seems that I have a 1.6 that has a smaller nipple than normal! Had to put a piece of bigger stuff around it and clamp it in that one spot. Worked fine everywhere else. Cheap too! Should be able to get it anywhere someone works on big trucks.
