Author Topic: Mechanic in moncton N-B  (Read 5623 times)
August 21, 2006, 03:32:39 pm
1slowvw
« on: August 21, 2006, 03:32:39 pm »
hey guys i need some help, my brother had a 1987 vw cabriolet and its making some really odd noises, noises that i dont recognise. So I know theres a couple New brunswickers on the site and im wondering is anyone can recomend a good VW mech in moncton or miramichi or even fredericton. If someone could i would really apreaciate it. Thanks in advance .
1slowVW
Reply #1August 21, 2006, 04:57:51 pm
« Reply #1 on: August 21, 2006, 04:57:51 pm »
I can't recommend a mechanic, but you could try posting an audio clip
Reply #2August 22, 2006, 07:36:59 am
addautomotive
« Reply #2 on: August 22, 2006, 07:36:59 am »
I don't know about fredericton, but there is a good shop here in SJ. Alpine Motors... 633-8490
Reply #3August 24, 2006, 05:26:34 am
stewardc
« Reply #3 on: August 24, 2006, 05:26:34 am »
In Fredericton, Gunther's VW on the Kilarney Rd.
Reply #4August 24, 2006, 09:32:31 am
shwartzbewithyou
« Reply #4 on: August 24, 2006, 09:32:31 am »
I know you probably don't care, but if you put a long screwdriver, prybar, or another peice of metal up to you rear, then you can touch it on the casing of each pump/pulley on the engine while it's running to see if a bearing is bad in one of the pumps.  If one of the pumps sounds different than the others than it may be your culprit.  Then again if your car sounds like a fog horn while speeding down the highway then your pumps and pulleys may have nothing to do with it.
Care to expand on this?
Reply #5August 24, 2006, 02:53:15 pm
1slowvw
« Reply #5 on: August 24, 2006, 02:53:15 pm »
hey guys thanks for the replies my brother ended up taking to car to Gunthers in fredericton.
And the screwdriver tip is definatly something I will remember.
Thanks again 1slowVW
