TDI Engine -General Info
gear ratios
Topic: gear ratios (Read 19458 times)
March 13, 2026, 12:34:57 pm
w1004thw
Newbie
I spend 2 mins using a tool, 2 hrs looking for it
gear ratios
March 13, 2026, 12:34:57 pm »
Does anyone have the gear ratios for these? I'mm trying to decide which would be a better fuel economy choice for an ALH tdi conversion to Tdi-M.
02a/j on 2001 ALH tdi
020 on 1998 ABA
March 13, 2026, 01:59:03 pm
Moderator
4553
Re: gear ratios
March 13, 2026, 01:59:03 pm »
This should give you enough information to ponder about.
http://www.scirocco.org/gears/
Just ID your transmission and the year and you should find the different ratios you desire.
Edit:::: Maybe not as these are mostly older transmissions and I just noticed you are more MODERN.
Last Edit: March 13, 2026, 02:01:59 pm by ORCoaster
May 31, 2026, 09:30:32 pm
Re: gear ratios
May 31, 2026, 09:30:32 pm »
Do you know the rest of the code?
There are many different codes for the 020.
An ABA might have an ACN with maybe a 3.67 ring and pinion that is good for the highway.
Some 02As are better than the 02Js, when it comes to lower RPM on the highway.
gear ratios
