Author Topic: "Idle spring" on bosch VE pump.  (Read 12028 times)
August 28, 2023, 02:23:15 am
DieselSNubbe
  • 2
« on: August 28, 2023, 02:23:15 am »
Hello fellow dieslers!
I have an old jetta 87 that i put a 1.6 td from a golf into. Everything works good except it wants to hang and sometimes run away at rpms over 2500. I heard that the idle spring could be stretched out to fix the problem and so i did. The fix worked for a while but now the problem is back, i guess the spring has been compressed again. Ive tried searching for a new spring online but i cant find one and i cant find a part number for the spring either. Does anyone know where i can find one or what part number it has?
Im not sure how to post pictures here so if someone could help me with that I could post a picture of the spring im talking about.
Thanks in advance!
Reply #1August 28, 2023, 07:18:30 pm
Re: "Idle spring" on bosch VE pump.
« Reply #1 on: August 28, 2023, 07:18:30 pm »
Use a third-party site to post your picture.  Send it to Imagur or Dropbox.  Then when writing a message use the box under the bold button to insert a link.  Copy the link from the picture place and insert it between the two types of image brackets.
Reply #2August 28, 2023, 09:59:57 pm
DieselSNubbe
  • 2
« Reply #2 on: August 28, 2023, 09:59:57 pm »
Thanks!
Im talking about the spring to the far left, left of the arrow on the picture :)
« Last Edit: August 29, 2023, 12:17:23 am by DieselSNubbe »
Reply #3August 29, 2023, 06:55:56 pm
« Reply #3 on: August 29, 2023, 06:55:56 pm »
You might try to put a washer in next to the spring and increase the tension that way.  Rather than pull on the spring and have it return to its original size over time.
