Author Topic: 1.6 Tach jumpy after 3k  (Read 4547 times)
August 25, 2022, 02:27:03 pm
33B
  • 58
    Bosnian with a money pit aka VW Passat 1987
« on: August 25, 2022, 02:27:03 pm »
1.6 tachometer jumping around after 3k rpm, or more exactly getting hung up.
Bad connection, bad tach, bad alternator?
1987 Passat B2 (33B)- 1.6TD JR, Audi 80 b4 front suspension and power steering. 280mm brake discs with 54mm calipers front. Rear MK3 disc setup with golf mk5 calipers.
Reply #1August 25, 2022, 04:55:12 pm
  • 4553
Re: 1.6 Tach jumpy after 3k
« Reply #1 on: August 25, 2022, 04:55:12 pm »
I would go with bad connections at the alternator and maybe in the back of the circuit board.  If You pull the cluster out you can put a direct connection to the signal of the tach and determine if there is a problem with the circuit board that way.
Hard to determine if the Alt signal is wonky without an oscilloscope I think.  No idea how to check that unless it is just a continuity check with a meter.
Reply #2August 29, 2022, 12:37:07 am
33B
  • 58
« Reply #2 on: August 29, 2022, 12:37:07 am »
Corroded male connection on alternator.
Thanks
Reply #3August 29, 2022, 06:45:42 pm
  • 4553
« Reply #3 on: August 29, 2022, 06:45:42 pm »
Don't you just LOVE those simple fixes?
