1.6 Tach jumpy after 3k
Topic: 1.6 Tach jumpy after 3k (Read 4546 times)
August 25, 2022, 02:27:03 pm
33B
Bosnian with a money pit aka VW Passat 1987
August 25, 2022, 02:27:03 pm »
1.6 tachometer jumping around after 3k rpm, or more exactly getting hung up.
Bad connection, bad tach, bad alternator?
1987 Passat B2 (33B)- 1.6TD JR, Audi 80 b4 front suspension and power steering. 280mm brake discs with 54mm calipers front. Rear MK3 disc setup with golf mk5 calipers.
August 25, 2022, 04:55:12 pm
Moderator
4553
Re: 1.6 Tach jumpy after 3k
August 25, 2022, 04:55:12 pm »
I would go with bad connections at the alternator and maybe in the back of the circuit board. If You pull the cluster out you can put a direct connection to the signal of the tach and determine if there is a problem with the circuit board that way.
Hard to determine if the Alt signal is wonky without an oscilloscope I think. No idea how to check that unless it is just a continuity check with a meter.
August 29, 2022, 12:37:07 am
33B
August 29, 2022, 12:37:07 am »
Corroded male connection on alternator.
Thanks
August 29, 2022, 06:45:42 pm
Moderator
4553
August 29, 2022, 06:45:42 pm »
Don't you just LOVE those simple fixes?
