Author Topic: 1.6d head, k24 turbo, ARP head studs, claudes brigges valve cover, 1.6d injection pump, 1.6d ecodies  (Read 18967 times)
Reply #30May 02, 2018, 08:40:33 am
dailydubber
  • 18
WTB: VW MK1 Tail light assembly
« Reply #30 on: May 02, 2018, 08:40:33 am »
I'm looking for a pair of tail light assembly for my 4-door VW Rabbit Diesel. Preferably minor cracks to no cracks. I've searched online but they're out of stock or no longer available. Please let me know shipped to 21061 Maryland USA. Thank you.
Sent from my HTC6545LVW using Tapatalk
Reply #31May 02, 2018, 08:40:45 am
dailydubber
  • 18
« Reply #31 on: May 02, 2018, 08:40:45 am »
Reply #32May 02, 2018, 08:40:53 am
dailydubber
  • 18
« Reply #32 on: May 02, 2018, 08:40:53 am »
Reply #33May 23, 2018, 09:28:41 am
Ian0391
  • 119
Dipsticks
« Reply #33 on: May 23, 2018, 09:28:41 am »
Can I use an alh dipstick and tube in am ahu/1z block?
Sent from my Pixel 2 using Tapatalk
Reply #34May 23, 2018, 09:28:53 am
Ian0391
  • 119
Dipsticks
« Reply #34 on: May 23, 2018, 09:28:53 am »
Reply #35May 23, 2018, 09:39:17 am
Ian0391
  • 119
Dipstick tube
« Reply #35 on: May 23, 2018, 09:39:17 am »
Is it possible to swap an alh dipstick assembly onto a 1z/ahu block?
Reply #36July 12, 2018, 04:15:00 am
Turbofan
  • 70
ALH Swap w/clutch cable in SE CT $1000
« Reply #36 on: July 12, 2018, 04:15:00 am »
A few years ago, I bought a 98 Beetle TDI for the express purpose of harvesting the engine/drivetrain to swap into my MK2. I also sourced a cable clutch setup from Germany, to speed up the process. Shortly there after, my first son was born, and free time went bye bye. I ended up selling the car in 2016, but held onto the swap.
The motor and transmission (02J) have about 163k on them, and I replaced the timing belt, tensioner, roller, and waterpump after pulling the motor. Also included is ecu, 2 engine wiring harnesses, a chassis harness, cluster (not needed- no immo in 98), shifter assembly, intercooler, radiator, and motor accessories. I've got several rubbermaid tubs of parts, and I'm sure there is even more in there. I'm located in Westport, CT, 06880. I'm happy to deliver this stuff within a reasonable distance in the chance you don't have a truck. I'd like to see this stuff get used! Let me know if you have questions.
P.S. I will only sell the cable clutch setup w/o the engine if the engine sells first,  and the buyer doesn't want it!
Thanks for looking!
Reply #37July 12, 2018, 04:29:35 am
Turbofan
  • 70
« Reply #37 on: July 12, 2018, 04:29:35 am »
Thanks for looking!
Reply #38July 12, 2018, 08:11:52 pm
Turbofan
  • 70
« Reply #38 on: July 12, 2018, 08:11:52 pm »
The motor and transmission have about 163k on them, and I replaced the timing belt, tensioner, roller, and waterpump after pulling the motor. Also included is ecu (80 pin), 2 engine wiring harnesses, a chassis harness, cluster (not needed- no immo in 98), shifter assembly, intercooler, radiator, Bentley Beetle Bible, and motor accessories. Also included is a rear 02a transmission bracket to aid mounting in a Mk1/2. I've got several rubbermaid tubs of parts, and I'm sure there is even more in there. I'm located in Westport, CT, 06880. I'm happy to deliver this stuff within a reasonable distance in the chance you don't have a truck. I'd like to see this stuff get used! Let me know if you have questions.
Thanks for looking!
Reply #39July 12, 2018, 08:12:00 pm
Turbofan
  • 70
« Reply #39 on: July 12, 2018, 08:12:00 pm »
Thanks for looking!
Reply #40December 17, 2018, 02:34:28 pm
mrurbina
  • 22
FS: ALH TDI ENGINE
« Reply #40 on: December 17, 2018, 02:34:28 pm »
***SHIPPING OFFER IS FOR ANY BUSINESS ADDRESS INC. TERMINAL IN THE LOWER 48***
$1200
*******please message me if you intend on using a residential address*****
DONOR:*2003 VOLKSWAGEN JETTA TDI*
MILEAGE:*245K
WHAT'S INCLUDED:*COMPLETE ENGINE AS REMOVED*
CAN INCLUDE*ECU*AND*HARNESS*AT OFFERED PRICE !
DIRECT FIT FOR 1998-2003 GOLF JETTA AND BEETLE ALH*
(noise in video is the serp. belt*tensioner)
https://www.youtube.com/watch?v=g5yZHgZS_7A
Sent from my SM-N950U using Tapatalk
Reply #41December 17, 2018, 02:34:42 pm
mrurbina
  • 22
FS: ALH TDI ENGINE
« Reply #41 on: December 17, 2018, 02:34:42 pm »
$1200
MILEAGE:*245K
Reply #42December 17, 2018, 02:35:15 pm
mrurbina
  • 22
FS: ALH TDI ENGINE
« Reply #42 on: December 17, 2018, 02:35:15 pm »
$1200
MILEAGE:*245K
Reply #43December 17, 2018, 02:36:38 pm
mrurbina
  • 22
FS: ALH ENGINE SWAP
« Reply #43 on: December 17, 2018, 02:36:38 pm »
$1200
MILEAGE:*245K
Reply #44March 10, 2019, 02:06:00 pm
DkmenchaR
  • 23
AGR Engine with K24 Turbo (NO M-TDI)
« Reply #44 on: March 10, 2019, 02:06:00 pm »
I got a used KKK24 Turbo from a Audi90 1.6TD at junkyard, and I'm wondering if, this particular turbo will be a good upgrade to my VNT15!
I've got already a Remap with a VNT convertion, but can I swap this little turbo to the K24 easily and re-adjust my ECU? I don't want mechanical pump, and my power goals is around 160-170hp at the wheels (currently with 128whp and 317nm on dyno)
I know some TDI's come with Wastegsted turbos, and I know there are other turbo options for that power goal, but this seems to be a nice turbo, inspite of the age... Besides, I don't want to chance to another turbo (The less I spend, the better!)
Any recommendation is well welcome!
Enviado do meu SM-J500FN através do Tapatalk
