For Sale/Looking For
Parts for Sale/Wanted
1.6d head, k24 turbo, ARP head studs, claudes brigges valve cover, 1.6d injection pump, 1.6d ecodies
Pages:
4
5
Topic: 1.6d head, k24 turbo, ARP head studs, claudes brigges valve cover, 1.6d injection pump, 1.6d ecodies (Read 18863 times)
Reply #45
March 10, 2019, 02:06:24 pm
DkmenchaR
User+
AGR Engine with K24 Turbo (NO M-TDI)
Reply #45 on:
March 10, 2019, 02:06:24 pm »
I got a used KKK24 Turbo from a Audi90 1.6TD at junkyard, and I'm wondering if, this particular turbo will be a good upgrade to my VNT15!
I've got already a Remap with a VNT convertion, but can I swap this little turbo to the K24 easily and re-adjust my ECU? I don't want mechanical pump, and my power goals is around 160-170hp at the wheels (currently with 128whp and 317nm on dyno)
I know some TDI's come with Wastegsted turbos, and I know there are other turbo options for that power goal, but this seems to be a nice turbo, inspite of the age... Besides, I don't want to chance to another turbo (The less I spend, the better!)
Any recommendation is well welcome!
Enviado do meu SM-J500FN através do Tapatalk
Reply #46
March 10, 2019, 02:06:35 pm
DkmenchaR
User+
Reply #46 on:
March 10, 2019, 02:06:35 pm »
Reply #47
March 10, 2019, 02:06:45 pm
DkmenchaR
User+
Reply #47 on:
March 10, 2019, 02:06:45 pm »
Reply #48
March 10, 2019, 02:07:34 pm
DkmenchaR
User+
Reply #48 on:
March 10, 2019, 02:07:34 pm »
Reply #49
March 10, 2019, 02:09:30 pm
DkmenchaR
User+
AGR Engine K24 Turbo Help
Reply #49 on:
March 10, 2019, 02:09:30 pm »
Reply #50
March 10, 2019, 02:11:09 pm
DkmenchaR
User+
Reply #50 on:
March 10, 2019, 02:11:09 pm »
Reply #51
March 10, 2019, 02:11:21 pm
DkmenchaR
User+
Reply #51 on:
March 10, 2019, 02:11:21 pm »
Reply #52
March 10, 2019, 02:13:18 pm
DkmenchaR
User+
AGR Engine K24 Turbo (NO M-TDI)
Reply #52 on:
March 10, 2019, 02:13:18 pm »
Reply #53
March 10, 2019, 02:35:33 pm
DkmenchaR
User+
Reply #53 on:
March 10, 2019, 02:35:33 pm »
Reply #54
March 10, 2019, 02:35:53 pm
DkmenchaR
User+
Reply #54 on:
March 10, 2019, 02:35:53 pm »
Reply #55
April 11, 2019, 12:19:10 pm
anchoredinchrist
1998 jetta ahu with 5th injector???
Reply #55 on:
April 11, 2019, 12:19:10 pm »
I have a 1998 jetta tdi in the shop right now, it's my brother in law's, and I was doing the wheel bearings and etc. I noticed that there was a check engine light, so I hooked up autel and checked and got code 00309 which is for the fifth injector metering device. I thought that there must be something wrong, and so I looked and sure enough, there is a fifth injector setup on this car! I thought maybe someone had maybe swapped in an engine from a 1996 Passat, but it doesn't appear that it has been changed. I didn't run the engine numbers, but I wanted to know if anyone else has run into this, and how to delete it in the ecu. It has already had an egr delete and tune. Is there a way to shut it off in vag-com? Thanks!
Sent from my KYOCERA-E6790 using Tapatalk
Reply #56
April 11, 2019, 12:19:17 pm
anchoredinchrist
Reply #56 on:
April 11, 2019, 12:19:17 pm »
Reply #57
April 11, 2019, 12:19:32 pm
anchoredinchrist
Reply #57 on:
April 11, 2019, 12:19:32 pm »
Reply #58
April 11, 2019, 12:19:39 pm
anchoredinchrist
Reply #58 on:
April 11, 2019, 12:19:39 pm »
Reply #59
April 11, 2019, 12:19:46 pm
anchoredinchrist
Reply #59 on:
April 11, 2019, 12:19:46 pm »
Pages:
4
5
