Author Topic: Need help ASAP  (Read 4240 times)
July 16, 2006, 07:18:05 pm
firestorm13666
  • 204
Need help ASAP
« on: July 16, 2006, 07:18:05 pm »
Well i have a misshap and lost the bolt that holds the speedo cable on the trans.I need to know what size it is so i can go get one or if someone in the use wants to send me one they have laying around that would be grate.Thanks
Reply #1July 16, 2006, 07:42:14 pm
Need help ASAP
« Reply #1 on: July 16, 2006, 07:42:14 pm »
Not sure but I think it's the same as the ones on the waterpump. Assuming this is a mk1 or mk2.
You can probably get away without one in the pump for a while while one is shipped to you.
Reply #2July 16, 2006, 08:05:01 pm
nkb
  • 154
Need help ASAP
« Reply #2 on: July 16, 2006, 08:05:01 pm »
if its the same on the water pump it would be a 6mx1.0
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
Reply #3July 16, 2006, 08:11:56 pm
firestorm13666
  • 204
Need help ASAP
« Reply #3 on: July 16, 2006, 08:11:56 pm »
Thanks guys i will go and buy one in the moring.
Reply #4July 16, 2006, 11:47:58 pm
  • 2931
trany speedo bolt
« Reply #4 on: July 16, 2006, 11:47:58 pm »
I don't think that's the same size bolt. It is nice to know the thread on the waterpump bolts, that's a common thread used throughout the engine bay.
 The speedo bolt is uncommon.
 It's probably closer to the 2 bolts that hold the tin cover to the lower part of the trany... the tin shield between the engine and trany.
 Grab the 11mm... or 7/16" wrench Pull one of the 2 bolts under the car, that hold the bottom of that tin shield to the trany... see if that's the right thread. .
Reply #5July 17, 2006, 02:12:56 am
firestorm13666
  • 204
Need help ASAP
« Reply #5 on: July 17, 2006, 02:12:56 am »
It had a 11mm head is it might be 8mmX1.25 pich?Like the allen head pully bolts on the engine.And i think it is like half a inch long.
Reply #6July 17, 2006, 05:33:13 am
Need help ASAP
« Reply #6 on: July 17, 2006, 05:33:13 am »
Mine didnt have that bolt in it, and It's stayed put for over a year now, I just tamped the metal "base" of the cable in to the transmission, seems to work fine.
84 Scirocco 8v
00 Camaro L36 M49
