General Information
Troubleshooting
MKI 1.6td swap problem
Topic: MKI 1.6td swap problem (Read 5488 times)
July 11, 2006, 03:16:09 pm
njcaddy
Newbie
July 11, 2006, 03:16:09 pm »
Hey everyone im very new to diesels but i just bought a caddy and i swapped a 1.6td into it and i seem to have a problem.
i got all the air out of the fuel line but it doesn't wanna run. i crank it and it will fire up and then die. I dunno if this is a common problem with mk1 td. but it seems like its not get fuel. Do i need to mod the fuel pump?seems like theres not enough pressure coming in the lines. Can someone please help im all out of ideas. thanks
July 11, 2006, 03:26:22 pm
July 11, 2006, 03:26:22 pm »
Are there any fuel or air blockages? When was the fuel filter replaced? What about the air filter? Maybe your starter isn't cranking fast enough to get it started, or your glow plugs aren't working. :? Lots of possibilties
July 12, 2006, 09:21:40 pm
njcaddy
Newbie
July 12, 2006, 09:21:40 pm »
i don't beleive theres any blockages.i just replaced the fuel filter.the engine ran in the other car and so did mine
July 13, 2006, 04:02:06 am
July 13, 2006, 04:02:06 am »
How long does it run for?
Did you swap the engine out and then into the caddy with no changes?
Was the caddy originally diesel?
July 13, 2006, 01:17:19 pm
July 13, 2006, 01:17:19 pm »
You might have a bad stop solenoid. Turn the key to run and see if it is getting 12V (it's the only wire on the IP) if not figure out why. Even if it is getting power it may be stuck closed. To check crack open an injector line and crank the car over, if you see fuel coming out the solenoid is good, if not and it is getting 12v then it's time to replace it.
July 24, 2006, 08:06:43 pm
njcaddy
Newbie
July 24, 2006, 08:06:43 pm »
yea i tested the little plunger thing.it works. the engine runs,but no throttle. the caddy was diesel.i had to change the mounts from mk2 to mk1.thats all.i hope it isn't the pump
and the truck idles,it doesn't die.it runs but nothing else
July 25, 2006, 05:14:02 pm
July 25, 2006, 05:14:02 pm »
try removing the return line and attatching a small funnel and filing the IP with diesel. Maybe there is an airlock ?
July 27, 2006, 02:17:14 pm
njcaddy
Newbie
July 27, 2006, 02:17:14 pm »
nope,i did that today.theres fuel going threw it and it just runs,no throttle what so ever. idles high now tho?
General Information
Troubleshooting
