Author Topic: What's "Central Electric"?  (Read 4653 times)
June 21, 2006, 06:52:15 pm
duffer
  • 164
« on: June 21, 2006, 06:52:15 pm »
On a 1990 Jetta 1.6TD, just to the left of the steering column.
it's marked "Central Electric" with an on/off toggle switch.
Can anyone explain what this is for. please?
Thanks
Reply #1June 21, 2006, 08:06:50 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #1 on: June 21, 2006, 08:06:50 pm »
I think its a crappy company that makes crappy electric hand tools that are sold at HarborFreight Tools.
If you dont know who that is look it up on Google...loads of cheap China stuff.
on a VW I really have no idea.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #2June 21, 2006, 08:28:55 pm
duffer
  • 164
« Reply #2 on: June 21, 2006, 08:28:55 pm »
Hmmmm.....
(Thinks)  :?
Nope. Doesn't really help.
   But thanks anyway
Reply #3June 22, 2006, 02:48:21 am
Darkness_is_spreading
  • 288
It could be anything
« Reply #3 on: June 22, 2006, 02:48:21 am »
Need more info on where the switch is and what it is directly connected too....
Also, Central Electric is not just a "crappy power tool company" they are a switch board and high power interface and control company.
http://www.poweraisle.com/
92 Jetta 1.6 T (Sleepin)
Reply #4June 22, 2006, 03:15:42 am
bhtooefr
  • 305
    • http://my.opera.com/bhtooefr
« Reply #4 on: June 22, 2006, 03:15:42 am »
Central Electric (in your case, Central Electric 2) is also what VW calls the wiring on their cars, especially Mk1s, Mk2s, and Mk3s (Mk1s and early Mk2s have CE1, late Mk2s and Mk3s have CE2).
But I've never heard of a toggle switch. I would imagine that toggling it could shut down the entire electrical system (at the battery and alternator?), by chance?
1986 Volkswagen Golf | 1.6L NA diesel | 5spd manual | Deep Cosmic Blue (LE5C) | aack, it's a parts car, now, too!
1992 Mazda Miata | 1.6L DOHC gasser | 5spd manual | Classic Red (SU)
Reply #5June 22, 2006, 07:59:01 am
duffer
  • 164
« Reply #5 on: June 22, 2006, 07:59:01 am »
Thank you for your responses.
I'll have to go check what the switch
is connected to.
Meanwhile, thanks again.
Reply #6June 22, 2006, 09:57:45 pm
LeeG
  • 401
« Reply #6 on: June 22, 2006, 09:57:45 pm »
I dont know if all model of VW have this or not, but my Canadian market '91 jetta does:  The black plastic part below the actual dashboard, just by the drivers door is embossed with the words 'central electric'.  below that is the plastic shelf/change tray thingy that snaps off to reveal the fuse panel etc.
As to what your toggle switch does  :?:  Does it look factory?
Maybe the P.O. built up the fuel and boost and the switch activates solenoid valves to cut the boost loose like Malone describes somewhere on here   :twisted:
Course its more likely to be some botched wiring fix to bypass the radiator fan thermal switch r something like that.
'97 Passat TDI
Reply #7June 23, 2006, 05:32:55 am
BlackTieTD
  • 1512
« Reply #7 on: June 23, 2006, 05:32:55 am »
my '90 jetta says central electric by the fuse panel too, but no switch. 99% sure that will be a switch that a PO added... tracing wires is fun :)
Reply #8June 23, 2006, 12:34:04 pm
duffer
  • 164
« Reply #8 on: June 23, 2006, 12:34:04 pm »
Yes.
Tracing wires can be "fun" (if you're a masochist).
Unfortunately, I haven't had the opportunity,yet, for
such a rollicking good time :roll: .
The switch doesn't look original and I think Lee is
right. It's probably something to do with the cooling fan.
The wiring looks decidedly "iffy".
Thanks for all the input.
