Author Topic: Can pistons from a JX be used in an RA??  (Read 6692 times)
May 22, 2006, 12:07:16 am
YoSono
  • 22
« on: May 22, 2006, 12:07:16 am »
I need a new set of pistons for my GTD, which is the RA engine code. Anyways, i've been looking on german ebay and have found loads of new ones for a JX engine code (think this is the engine that came in the T3) they seem to be the same diameter, and have the little cutouts for the oil squirters, but i was wanting to make sure if they were the same.
can anyone help with this issue?
cheers
lee.
Reply #1May 22, 2006, 03:57:11 am
regcheeseman
  • 714
« Reply #1 on: May 22, 2006, 03:57:11 am »
Lee,
Andy's (ART1234) just picked up a 1.6 passat TD with a blown motor - he's gonna split it for bits and there should be some pistons going spare.
Reply #2May 22, 2006, 05:49:51 am
Re: Can pistons from a JX be used in an RA??
« Reply #2 on: May 22, 2006, 05:49:51 am »
Quote from: YoSono
cheers
lee.
Unfortunately, they are not the same part number.   The pistons in the JX are used in almost every 1.6TD except for the RA.  Not sure what the difference is, and they might actually work but I dont know that information.  Hope that helps.
84 Scirocco 8v
00 Camaro L36 M49
Reply #3October 06, 2011, 11:04:01 pm
Alcaid
  • 549
« Reply #3 on: October 06, 2011, 11:04:01 pm »
Bumping an oldie, but does anyone know the actual difference between the RA/SB pistons and the normal 1.6TD pistons?
'10 VW Passat 1.6TDI Highline
Reply #4October 07, 2011, 01:59:22 am
Mark(The Miser)UK
  • 1557
« Reply #4 on: October 07, 2011, 01:59:22 am »
cheers
lee.
RA engines out for a short while and were parralleled /superceded by the SB engines. SB pistons have same part number as RA.
Reg might be able to see if the piston crowns are different to standard TD.
I wonder if they are lighter?
At least the SB/RA/JX use the same rings...
Mark-The-Miser-UK
Reply #5October 07, 2011, 02:12:34 am
Alcaid
  • 549
« Reply #5 on: October 07, 2011, 02:12:34 am »
Wow, useful post Mark.....  ::)
Does anyone have both pistons at hand and can compare them so that we can get the facts instead of Mark's theories?  :P
Reply #6October 07, 2011, 04:37:16 am
Mark(The Miser)UK
  • 1557
« Reply #6 on: October 07, 2011, 04:37:16 am »
Well that was bloody rude :P
I got my info from VW's 'KATE'
Don't freeze to death  in Norway you git... 8)
Mark-The-Miser-UK
Reply #7October 07, 2011, 05:41:59 am
Alcaid
  • 549
« Reply #7 on: October 07, 2011, 05:41:59 am »
Hehe, just saying that since I asked for the difference between the RA/SB pistons and the ones on all the others, it is already a fact that the RA and SB pistons are the same but different from the ones all the other 1.6TD uses. No need for you to state the same thing all over ;) That they have the same piston rings I already knew and that wasn't even the question. Just getting a bit tired of your blue texting all over the place, that's all :P
Reply #8October 07, 2011, 06:00:41 am
Mark(The Miser)UK
  • 1557
« Reply #8 on: October 07, 2011, 06:00:41 am »
Alas I didn't see your one-liner mentioning SB for the first time in the thread.
Perhaps you didn't read my post where I said that 'Reginald' had some to hand. I think his are still in blocks though, although I could be wrong.
The facility for writing in blue is provided by the forum. I don't write in black ever since smudging ink when writing lefthanded with a quill at school, and getting punished for it. :o
Mark-The-Miser-UK
Reply #9October 07, 2011, 06:04:39 am
Alcaid
  • 549
« Reply #9 on: October 07, 2011, 06:04:39 am »
I'm left handed as well, so know all about the ink smearing!
Reply #10October 07, 2011, 06:14:14 am
Mark(The Miser)UK
  • 1557
« Reply #10 on: October 07, 2011, 06:14:14 am »
Did you write weird upside down like with a broken wrist? I just kept the paper straight. :-\
Mark-The-Miser-UK
Reply #11October 07, 2011, 06:17:15 am
Alcaid
  • 549
« Reply #11 on: October 07, 2011, 06:17:15 am »
I just changed to a fast drying pen, why make it more complicated? ;)
Reply #12October 07, 2011, 08:33:52 am
Mark(The Miser)UK
  • 1557
« Reply #12 on: October 07, 2011, 08:33:52 am »
You mean a biro? The Reverend Cook said biros encourage slovenly behaviour, as he tore out a page of writing for missing out the top line. Couldn't meet a nicer bloke after I left the school though
Mark-The-Miser-UK
Reply #13October 07, 2011, 01:04:16 pm
Mark(The Miser)UK
  • 1557
« Reply #13 on: October 07, 2011, 01:04:16 pm »
Research on  pistons gives me the following, with a surprise placing for the CY piston, which ran for 7 years in the Quantum here in the UK and began nearly 9 years before  intercooled stuff...
According to VAG:
068 107 065 BC
is 1V, JR, MF, and JX Turboed and CY mechanical head
068 107 065 AT
is RA, SB, Turbo intercooled and hyraulic CY Turboed!
068 107 065 AQ
is JP, CS and ME
Just seen that in America there was a piston that was 10 thou lower to allow for head reworking. Only available in the rebored versions :o
« Last Edit: October 07, 2011, 02:58:33 pm by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #14October 07, 2011, 01:27:43 pm
Alcaid
  • 549
« Reply #14 on: October 07, 2011, 01:27:43 pm »
My ETKA shows 068 107 065 BC for the CY as one would expect ???
CY as in the engine I have in my mk1 GTD
« Last Edit: October 07, 2011, 01:29:47 pm by Alcaid »
