Author Topic: Can pistons from a JX be used in an RA??  (Read 6693 times)
Reply #15October 07, 2011, 02:46:13 pm
Mark(The Miser)UK
  • 1557
Re: Can pistons from a JX be used in an RA??
« Reply #15 on: October 07, 2011, 02:46:13 pm »
My ETKA shows 068 107 065 BC for the CY as one would expect ???
CY as in the engine I have in my mk1 GTD
What a mess...Just checking... OK so you have a GTD that dated as to 82/83 ish? Non intercooled? Golfs did use the CY TD  then, and you are correct, used the BC piston :o Then by late 1984  Golfs had the JR.
The CY was unusual in that it survived becoming hydraulic. 1981 to 1986 in the 'mk2 Passat [Quantum] was also 'BC' . It was on turning hyfdraulic, that the piston in CY  became same as RA/SB.
I'll amend  the list thanks. What edition of KATE do you have? I have version 7 and 5.5.  I'd love an earlier  version
Mark-The-Miser-UK
Reply #16October 07, 2011, 11:58:26 pm
Alcaid
  • 549
« Reply #16 on: October 07, 2011, 11:58:26 pm »
ver.7
'10 VW Passat 1.6TDI Highline
Reply #17October 08, 2011, 03:00:04 am
Mark(The Miser)UK
  • 1557
« Reply #17 on: October 08, 2011, 03:00:04 am »
ver.7
It's so full of blanks of the interesting stuff at crossover between mk1 and mk2.
Does anyone have an early Euro 'KATE' [ver 1 , 2  or 3?] out there who could send me a copy?
Mark-The-Miser-UK
