Author Topic: wrong pump?  (Read 7309 times)
May 15, 2006, 08:03:24 pm
nkb
  • 154
wrong pump?
« on: May 15, 2006, 08:03:24 pm »
my car is a 93 1.9td, is this the right pump? theres nothing under this cover like any pics ive seen...
2004 Jetta TDI
1997 GMC Suburban 6.5td
2002 S-10 AWD V8 turbo, Sy-clone
1986 S-10 LT1
Reply #1May 15, 2006, 08:28:38 pm
QuickTD
  • 1156
wrong pump?
« Reply #1 on: May 15, 2006, 08:28:38 pm »
There were a few AAZ's built in the early years that did not have an LDA, similar to the 1V ecodiesel in the US. Most were passats.
 To get more fuel under boost you would ahve to do the same thing as ecodiesel owners, install either a complete TD pump or the top cover and LDA from one.
Reply #2May 15, 2006, 10:03:36 pm
commuter boy
  • 277
wrong pump?
« Reply #2 on: May 15, 2006, 10:03:36 pm »
I've got the same pump.  You likely also have the single stage injectors and the matching fuel lines.
The turbo I have doesn't seem to have an adjusting arm to increase the boost either.
Mid way through 1993 the Passats stopped coming with this setup, if the Bosch nozzle book I saw last year is accurate.
Reply #3May 15, 2006, 10:11:26 pm
nkb
  • 154
wrong pump?
« Reply #3 on: May 15, 2006, 10:11:26 pm »
my car is a passat too.. damn. so what pump off what car should i use?
2004 Jetta TDI
1986 S-10 LT1
Reply #4May 16, 2006, 06:47:50 am
QuickTD
  • 1156
wrong pump?
« Reply #4 on: May 16, 2006, 06:47:50 am »
I don't know where you live, your location isn't listed in your profile, so its difficult to tell you what models to look for...
 Assuming you're in Canada, The pump from a 93-94 golf or jetta would work. The pump from 95-97 models will fit but the entire bracket assembly from newer engine must be used.
Reply #5May 18, 2006, 12:49:18 pm
nkb
  • 154
wrong pump?
« Reply #5 on: May 18, 2006, 12:49:18 pm »
will 1.6td pump parts fit? i can get a whole engine for free
2004 Jetta TDI
1986 S-10 LT1
Reply #6May 30, 2006, 02:13:57 pm
nkb
  • 154
wrong pump?
« Reply #6 on: May 30, 2006, 02:13:57 pm »
anyone tried it? i now own 2 td passats with this damn pump
2004 Jetta TDI
1986 S-10 LT1
Reply #7June 03, 2006, 11:14:24 am
evangelos
wrong pump?
« Reply #7 on: June 03, 2006, 11:14:24 am »
i have the same pump and woncering what i can do.
what is the advantage to having done this? better mileage out of the entine?
evan
Reply #8June 04, 2006, 02:33:09 pm
commuter boy
  • 277
wrong pump?
« Reply #8 on: June 04, 2006, 02:33:09 pm »
I've heard Giles at Superior Fuel Injection can replace the pump top at the same time he does a rebuild.
You will also need to get the dual stage injectors from a golf or jetta of the same vintage, and the matching fuel lines (or bend the existing ones to fit, which may be a bit of a dodgy proposition, given their age).
Or, just swap pumps & injectors & lines from a golf or jetta.
The pump was designed to not dump more fuel in when the boost cranks up, which means it burns very clean at higher rpms.
You'll also find you've got a non-adjustable turbo, which may be problematic if you're looking at upgrading the pump for power reasons.
What type of mileage are you getting out of your Passats?  I'm only getting 800-850 out of a tank, tops.
Reply #9June 04, 2006, 05:12:26 pm
evangelos
wrong pump?
« Reply #9 on: June 04, 2006, 05:12:26 pm »
i actually have a jetta but the engine was replaced completely. i was told it had 150K. it runs fine.
so i basically have a very low boost - next to nothing but a more efficient engine.
basically 1.9NA power wise
evan
Reply #10June 13, 2006, 09:18:26 pm
nkb
  • 154
wrong pump?
« Reply #10 on: June 13, 2006, 09:18:26 pm »
what about machining the top? the thing looks like its pretty straight forward
if someone knew what they were doing. but of course i haven't a clue..
i haven't even seen one of these with the boost enrichment before on the 1.9s but ive only seen a few 1.9s...
2004 Jetta TDI
1986 S-10 LT1
Reply #11June 14, 2006, 06:25:08 am
evangelos
wrong pump?
« Reply #11 on: June 14, 2006, 06:25:08 am »
i just recieved a leaking pump from a 95 golf  with the ldr but i am nor sure if all i have to do is add the missing parts and bingo!
i have next to zero knowledge on IP's.
can any ease my weary mind about this matter?
evan
