Author Topic: cleaning injectors?  (Read 5382 times)
May 14, 2006, 04:42:02 pm
SMOKEYDUB
  • 630
cleaning injectors?
« on: May 14, 2006, 04:42:02 pm »
I got my car misfired....... i mean started :D  and it misfires and all the fuel is bled. i think i have an injector sticking because it whit smokes like crazy and the little return lines on the injectors are getting pressurized. so what do you think if i took it apart cleaned them up and put them exactly back togehter the way they came apart.
thanks
jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #1May 15, 2006, 12:10:07 pm
Mark(The Miser)UK
  • 1557
Re: cleaning injectors?
« Reply #1 on: May 15, 2006, 12:10:07 pm »
Quote from: SMOKEYDUB
thanks
jeff
[/color][/size]
Jeff how do you know your returns are presurised?
   :idea: To be sure its not pump return fuel. Plug return tube that goes to return banjo.  Thus all fuel you see is injector xs. If you get more than almost nothing; then remove all rubber lines and see which injector is spewing :idea:
Mark-The-Miser-UK
Reply #2May 15, 2006, 01:03:45 pm
shwartzbewithyou
cleaning injectors?
« Reply #2 on: May 15, 2006, 01:03:45 pm »
Could be plugged return line.
I ran diesel injector cleaner and it cleaned up all my injectors amazingly.  I never thought it did that much but it's worth a shot after it's all said and done.
Reply #3May 15, 2006, 03:57:25 pm
SMOKEYDUB
  • 630
cleaning injectors?
« Reply #3 on: May 15, 2006, 03:57:25 pm »
i have all brand new return lines so im going to pull them off to see which one is spewing.  thanks
jeff
(courtesy of GILES)
Reply #4May 15, 2006, 04:10:33 pm
hillfolk'r
  • 1532
cleaning injectors?
« Reply #4 on: May 15, 2006, 04:10:33 pm »
take them apart,clean them,reassemble them,,its no problem ,i do it all the time,,just do one at a time so you dont mix up parts................
Throttle cables ftw
Reply #5May 15, 2006, 06:06:17 pm
dennis m king
  • 36
cleaning injectors?
« Reply #5 on: May 15, 2006, 06:06:17 pm »
i will add if they got a good bit of miles on them up here they get about 45 bucks per hole to redo the injectors. and you usually can tell the idle is smoother when they hand set the opening psi close together vs factory good enough in spec.
86td jetta
96 dodge td ram
86 gpz750 turbo
i like turbos
Reply #6May 15, 2006, 06:10:25 pm
cleaning injectors?
« Reply #6 on: May 15, 2006, 06:10:25 pm »
hey sounds like my problem.  one of my injectors started spewing one day, and the return line looked like it was eaten or chewed.. pretty disgusting so diesel leaking all down my engine, not cool.  I've got 4 rebuilt injectors coming soon and I hope that fixes the problem.
also, diesel leaks into my cylinders and is mixing with my oil...  can't be good to drive it. :(  I'm guessing leaky injectors are broken, and not just 'stuck'
Reply #7May 15, 2006, 06:15:28 pm
dennis m king
  • 36
cleaning injectors?
« Reply #7 on: May 15, 2006, 06:15:28 pm »
be carefull with leaky injectors. it can cause fuel knock on startup.
86td jetta
96 dodge td ram
86 gpz750 turbo
i like turbos
Reply #8May 15, 2006, 08:16:07 pm
fspGTD
  • 1529
cleaning injectors?
« Reply #8 on: May 15, 2006, 08:16:07 pm »
IDI Diesel is for performance enhancement discussion only.  Moved to troubleshooting section.
Jake Russell
