1Y conrod bearing set number
Topic: 1Y conrod bearing set number (Read 2959 times)
April 07, 2019, 08:02:45 pm
thebilgerat
Newbie
April 07, 2019, 08:02:45 pm »
Does anyone have a good number for a conrod bearing set for the 1Y? The parts supplier sent me bearings for an AAZ which do not appear to be the same at all.
Thanks!
April 07, 2019, 08:42:18 pm
thebilgerat
Newbie
Re: 1Y conrod bearing set number
April 07, 2019, 08:42:18 pm »
So after some searching it seems that the 1.6L diesel conrod bearings are the ones I want. Are the conrod bearing ends the same diameter as the 1Y? Or do I need to buy oversize/undersize? Rods are standard.
April 08, 2019, 07:29:04 am
April 08, 2019, 07:29:04 am »
are you talking about the small end?
April 08, 2019, 01:24:20 pm
April 08, 2019, 01:24:20 pm »
The big-end journal diameter for the 1.6 and the AAZ is the same. I don't know about the 1Y. If it is different from the AAZ then it is different from the 1.6.
April 09, 2019, 11:39:48 am
thebilgerat
Newbie
April 09, 2019, 11:39:48 am »
The problem with the AAZ bearings are the notch. The 1Y has a small style notch while the AAZ notch is large and goes completely to the edge. The 1Y rod bearing notch does not go to the edge.
The wrist pin bearings I don't need (small end)
