Author Topic: 1Y conrod bearing set number  (Read 2957 times)
April 07, 2019, 08:02:45 pm
thebilgerat
  • 8
« on: April 07, 2019, 08:02:45 pm »
Does anyone have a good number for a conrod bearing set for the 1Y?  The parts supplier sent me bearings for an AAZ which do not appear to be the same at all.
Thanks!
Reply #1April 07, 2019, 08:42:18 pm
thebilgerat
  • 8
Re: 1Y conrod bearing set number
« Reply #1 on: April 07, 2019, 08:42:18 pm »
So after some searching it seems that the 1.6L diesel conrod bearings are the ones I want.  Are the conrod bearing ends the same diameter as the 1Y?  Or do I need to buy oversize/undersize?  Rods are standard.
Reply #2April 08, 2019, 07:29:04 am
  • 5104
« Reply #2 on: April 08, 2019, 07:29:04 am »
are you talking about the small end?
Reply #3April 08, 2019, 01:24:20 pm
« Reply #3 on: April 08, 2019, 01:24:20 pm »
The big-end journal diameter for the 1.6 and the AAZ is the same.  I don't know about the 1Y.  If it is different from the AAZ then it is different from the 1.6.
Reply #4April 09, 2019, 11:39:48 am
thebilgerat
  • 8
« Reply #4 on: April 09, 2019, 11:39:48 am »
The problem with the AAZ bearings are the notch.  The 1Y has a small style notch while the AAZ notch is large and goes completely to the edge.  The 1Y rod bearing notch does not go to the edge.
The wrist pin bearings I don't need (small end)
