Author Topic: GTD nozzles tested!  (Read 3203 times)
April 11, 2006, 02:04:00 pm
turbotor
  • 50
GTD nozzles tested!
« on: April 11, 2006, 02:04:00 pm »
Today I put in my new GTD nozzles, very easy job with the hardware kit including retur hose and the seals form TDtuning!!  :D
Its dark outside now so I didnt see how its smoking, need to take adjustment tomorrow.
BUT....I think engine is a little bit more noisy now...more rattle, more diesel sound. (The old nozzles was very worn, I dont think they have been changed sinze car was new.....)
Maybe I have to back of timeing a bit to get ride of the noise??
Reply #1April 14, 2006, 05:44:32 am
turbotor
  • 50
GTD nozzles tested!
« Reply #1 on: April 14, 2006, 05:44:32 am »
Because I wasnt pleased with the resault I pulled the injectors from the engine and did a pop test.....lowest was 137 and one was 150 bar.
Big difference in spray pattern too.
Now I have shimmed the injectors to 165 bar and they now spray the same.
Have to put them in and test drive...... 8)
Reply #2April 14, 2006, 08:11:48 am
turbotor
  • 50
GTD nozzles tested!
« Reply #2 on: April 14, 2006, 08:11:48 am »
Now i have been test driving again.....starting was great, still a little more diesel sound even when its warm. Pulls maybe a little better but biggest difference is that the smoke is mostly gone!! :) EGT is lower also!
Reply #3May 16, 2006, 04:04:57 am
Rat407
  • 289
GTD nozzles tested!
« Reply #3 on: May 16, 2006, 04:04:57 am »
I was looking at getting some GTD nozzles. I wonder what a difference I would see since I had my pump done by Giles?  Anyone else have anything to say about GTD nozzles?
AMSOIL Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta  ECO TD
Reply #4May 16, 2006, 06:18:13 am
Dr. Diesel
  • 1341
GTD nozzles tested!
« Reply #4 on: May 16, 2006, 06:18:13 am »
i wonder if you'd have noticed the same difference from an overhauled set of OE nozzles?
Reply #5May 16, 2006, 07:10:42 am
GTD nozzles tested!
« Reply #5 on: May 16, 2006, 07:10:42 am »
my car smoked
less, sounded different, and ran much smoother after the new injectors went in.
Reply #6May 16, 2006, 07:55:03 am
addautomotive
GTD nozzles tested!
« Reply #6 on: May 16, 2006, 07:55:03 am »
Quote from: Trev0rbr
my car smoked, sounded different, and ran much smoother after the new injectors went in.
Ditto
