GTD nozzles tested!
Topic: GTD nozzles tested! (Read 3198 times)
April 11, 2006, 02:04:00 pm
turbotor
GTD nozzles tested!
April 11, 2006, 02:04:00 pm »
Today I put in my new GTD nozzles, very easy job with the hardware kit including retur hose and the seals form TDtuning!!
Its dark outside now so I didnt see how its smoking, need to take adjustment tomorrow.
BUT....I think engine is a little bit more noisy now...more rattle, more diesel sound. (The old nozzles was very worn, I dont think they have been changed sinze car was new.....)
Maybe I have to back of timeing a bit to get ride of the noise??
April 14, 2006, 05:44:32 am
turbotor
GTD nozzles tested!
April 14, 2006, 05:44:32 am »
Because I wasnt pleased with the resault I pulled the injectors from the engine and did a pop test.....lowest was 137 and one was 150 bar.
Big difference in spray pattern too.
Now I have shimmed the injectors to 165 bar and they now spray the same.
Have to put them in and test drive......
April 14, 2006, 08:11:48 am
turbotor
GTD nozzles tested!
April 14, 2006, 08:11:48 am »
Now i have been test driving again.....starting was great, still a little more diesel sound even when its warm. Pulls maybe a little better but biggest difference is that the smoke is mostly gone!!
EGT is lower also!
May 16, 2006, 04:04:57 am
Rat407
Authorized Vendor
GTD nozzles tested!
May 16, 2006, 04:04:57 am »
I was looking at getting some GTD nozzles. I wonder what a difference I would see since I had my pump done by Giles? Anyone else have anything to say about GTD nozzles?
AMS
OIL
Synthetic Lubricants & Filtration Systems, Click Here
Wholesale pricing available!
1991 Jetta ECO TD
May 16, 2006, 06:18:13 am
Dr. Diesel
Authorized Vendor
GTD nozzles tested!
May 16, 2006, 06:18:13 am »
i wonder if you'd have noticed the same difference from an overhauled set of OE nozzles?
May 16, 2006, 07:10:42 am
GTD nozzles tested!
May 16, 2006, 07:10:42 am »
my car smoked
less, sounded different, and ran much smoother after the new injectors went in.
May 16, 2006, 07:55:03 am
addautomotive
GTD nozzles tested!
May 16, 2006, 07:55:03 am »
Quote from: Trev0rbr
my car smoked, sounded different, and ran much smoother after the new injectors went in.
Ditto
GTD nozzles tested!
