General Information
Troubleshooting
Viton IP seals?
Topic: Viton IP seals? (Read 4651 times)
September 26, 2016, 08:47:17 am
Rattlebox
Newbie
Viton IP seals?
September 26, 2016, 08:47:17 am »
I guess I will be looking into rebuilding my spare pump ( TD pump can be used on an IDI?).
I also have a little leak on the top of my currently installed pump at the throttle shaft. I have been running too much dinodiesel.
Where can I get a seal kit/rebuild kit with biodiesel in mind?
Also I remember a guy named Vince waldron or something of the sorts that had websites for IP rebuilding etc. I cannot find them now. Anyone got a link?
85 Jetta 1.6d Wolfsburg.
Will perform some Mk1/2 diesel services in the NE Ga/Upstate SC and WNC areas. Timing belts and accessories, IP timing, Injector installs, mechanical lifter valve adjustments.
September 27, 2016, 09:27:21 am
Rattlebox
Newbie
Re: Viton IP seals?
September 27, 2016, 09:27:21 am »
I figured this would be a simple question to answer. I cannot find any Viton IP seals. Also the only reseal kit I find that looks close to the Bosch dgk-126 is listed as being for a TD. Is the gasket set different for my N/A?
September 27, 2016, 10:09:43 pm
Re: Viton IP seals?
September 27, 2016, 10:09:43 pm »
The authentic Bosch seal kits have been 100% biediesel compatible since the 90's.
The DGK-126 has the cold start o-ring but is missing the aneroid feeler pin o-ring which is part # 1-460-210347. The DGK-121 has the feeler pin o-ring but is missing the cold start o-ring. Neither kit comes with the main shaft seal which is part # 1-460-283-312.
I have gotten quite a few seal kits and individual Bosch seals/o-rings from the ebay seller angelofishes. He has always given me very good prices and very good customer service.
September 27, 2016, 10:18:31 pm
Rattlebox
Newbie
Re: Viton IP seals?
September 27, 2016, 10:18:31 pm »
I should have known about the biodiesel compatibility since I am German and know they run a high percentage of biodiesel there.... Thanks for the info.
General Information
Troubleshooting
Viton IP seals?
