General Information
Troubleshooting
What Should I Do with this TD Engine?
Topic: What Should I Do with this TD Engine? (Read 5583 times)
April 09, 2006, 06:26:16 pm
BioDieselVW
April 09, 2006, 06:26:16 pm »
I just bought a 91 Eco Diesel TD 1.6 to be swapped into my 81 Caddy. Before i swap it in I was wondering what I should do to it. It has 150k Is a full rebuilt necasary? What can I check to tell what should be done? Will a timming belt water pump and new gaskets and seals be sufficent or will it be to worn. The turbo has no shaft play but has oil in the housing. Please help!
81 Caddy 1.6 TD
Callaway Intercooler
4in Exhaust Stack
Super Pump !
April 09, 2006, 06:34:09 pm
April 09, 2006, 06:34:09 pm »
the oil could just be from the crank case vent.
April 09, 2006, 09:01:16 pm
wyldman
Authorized Vendor
April 09, 2006, 09:01:16 pm »
The oil in the housing is from the crankcase,probably due to blowby.
If it's not in bad shape,you can get away with honing and reringing it.Throw a 1.9L head gasket on while the head is off.Rebuild the head,and do some minor porting.Drill the manifold for an EGT probe while the head is off,it easier,even if you just throw a plug in it for now.
Use a 1.9L windage tray oil pan gasket too,it's worth a few HP and some fuel mileage.
(416)565-7282
April 10, 2006, 07:48:54 pm
BioDieselVW
April 10, 2006, 07:48:54 pm »
What year and make 1.9 head gasket? US or Canadian. Just curious why use a 1.9 head gasket?
81 Caddy 1.6 TD
4in Exhaust Stack
Super Pump !
April 11, 2006, 05:42:47 am
wyldman
Authorized Vendor
April 11, 2006, 05:42:47 am »
The 1.9L (93-97) AAZ motor used a steel shim metal head gasket.Super strong,and rarely fails.Why use the stock 1.6L gasket which could fail ?
(416)565-7282
April 11, 2006, 08:07:39 pm
mnoll406
User+
April 11, 2006, 08:07:39 pm »
Wyldman,
Can you use the same head gasket on a 81 NA with the 12mm head.
Mike
April 11, 2006, 08:24:57 pm
wyldman
Authorized Vendor
April 11, 2006, 08:24:57 pm »
No,it won't work.
(416)565-7282
April 12, 2006, 01:10:55 pm
fspGTD
April 12, 2006, 01:10:55 pm »
Moved to troubleshooting section. not power enhancement related!
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
July 18, 2006, 11:50:30 pm
avocado_tom
July 18, 2006, 11:50:30 pm »
Check the intermediate shaft bearings while it is out of the car.
Andrew
How does one check the I-shaft bearings? i.e. how can I tell if they're bad or not?
I'm just about to start digging in to my engine and I'd like to check them.
Cheers,
avocado
General Information
Troubleshooting
