Author Topic: WTB left side motor mount TDi into vanagon  (Read 6794 times)
December 25, 2015, 09:33:03 pm
rsvp
  • 21
« on: December 25, 2015, 09:33:03 pm »
hi All,
also looking for a left side motor mount that allows the TDI motor to fit into the Vanagon diesel. let me know if you're not planning on using yours...
thanks,
Steve
Reply #1December 28, 2015, 08:07:46 am
Re: WTB left side motor mount TDi into vanagon
« Reply #1 on: December 28, 2015, 08:07:46 am »
That depends on what turbo you plan on using.
Reply #2December 28, 2015, 09:11:09 pm
« Reply #2 on: December 28, 2015, 09:11:09 pm »
saw this and thought someone might need it.  http://eugene.craigslist.org/pts/5348149125.html  Vanagon Diesel motor mount kit.
Reply #3December 29, 2015, 07:37:01 am
rsvp
  • 21
« Reply #3 on: December 29, 2015, 07:37:01 am »
Hi, and thanks for the reply!,
That's a good deal for someone, but it's not what I need.
I'm looking for a custom made bracket, that allows the stock TDI turbo clearance when installed on a vanagon diesel. this was made by Greaseworks (and others folks) specifically for this application.
regards,
Steve
Reply #4December 29, 2015, 08:39:10 am
« Reply #4 on: December 29, 2015, 08:39:10 am »
If you are talking about the stock K03 or GT15, you might want to reconsider.  The AAZ K03 or T2 with matching manifold will fit without interference using the stock mounting bracket and give similar performance.  You could also use the AAZ manifold and build an adapter plate to mount the stock turbo without interference.  Either way, you may find it's less work than remaking the mounting bracket or trying to source a used modified one.  IMO, there are better turbo choices, though.
Reply #5January 04, 2016, 01:59:52 pm
rsvp
  • 21
« Reply #5 on: January 04, 2016, 01:59:52 pm »
hi Andrew,
What do you think is a better turbo? i'm inclined to keep the turbo that came with the 1Z/AHU as it's already there... but interested in what you think would be an improvement.
thanks,
Steve
Reply #6January 11, 2016, 10:40:51 am
danielgetsthis
  • 3
« Reply #6 on: January 11, 2016, 10:40:51 am »
Is this what you are looking for?
ebay.com/itm/VW-Bus-T2-T3-Engine-subframe-Engine-1-9-TDI-1Z-or-AFN-Conversion-/252145573321?hash=item3ab50c1dc9:g:wucAAOSwWKtUv5HS&vxp=mtr
Search eBay for "VW Bus T2 T3 Engine subframe Engine 1,9 TDI 1Z or AFN Conversion"
Sorry, the site doesn't let me post a link  ???
Reply #7January 11, 2016, 01:32:39 pm
rsvp
  • 21
« Reply #7 on: January 11, 2016, 01:32:39 pm »
I saw that when searching, and I  THINK it would work, but it looks like it'll need more adapters/ motor mounts to make it work...
here's another "link" to a US builder, Tony Sanchez, who advertizes on THE SAMBA.
http://www.thesamba.com/vw/classifieds/detail.php?id=1731371
I've been in contact with Tony, and he can make up one in short time, and he's easy to chat with.
So, now there's two builders of these mounts, in addition to those made but NLA from Justin at Greaseworks.
thanks,
Steve
Reply #8April 10, 2016, 10:44:21 am
rotaecho
  • 33
« Reply #8 on: April 10, 2016, 10:44:21 am »
Note, Tony no longer makes a support for the stock diesel vanagon carrier bars, but only the 83.5 and newer carrier bars.
I contacted that place over the pond to see about it. As I am on the hunt for an 82' carrier bar mount.
-Will
1982 Westfalia 1.6na diesel aka Betsy Bertha The Tortoise
Reply #9April 18, 2016, 01:42:46 pm
« Reply #9 on: April 18, 2016, 01:42:46 pm »
The aluminum brackets for the '82 vs. '83+ are the same aside from one very small hole for the mount alignment pin which is very easy to add.  If someone is selling a bracket that fits an '83+ it should also fit the '82.
