Fixmyvw.com
Author Topic: AC Clutch cuts out  (Read 3105 times)
June 29, 2015, 08:17:24 am
WeekendMechanic
  • 78
AC Clutch cuts out
« on: June 29, 2015, 08:17:24 am »
Ac works nice and cold but when I accelerate and drop revs at once it cuts out,I confirmed this was an electrical issue when I left the engine running and put the multimeter to the two terminals of the plug of the compressor, when I revved the engine very quickly the voltage would drop to 0v pretty quick but if I do it slowly it wont cut out, its not the trinity switch either as I also tried it with pins jumped on that.
Thing is this is a 1997 golf mk3 GTD with an aaz engine, no climatronic, and has no ECU and no relay, it only has a fan control module so how does it know that the engine is at low revs to cut out the clutch what am I missing?
I really don`t wont it cycle off and on.
Thanks
« Last Edit: June 29, 2015, 08:20:01 am by WeekendMechanic »
Reply #1July 24, 2015, 02:24:20 am
air-cooled or diesel
Re: AC Clutch cuts out
« Reply #1 on: July 24, 2015, 02:24:20 am »
not exactly on topic;,i have seen a/c's in older cars having wot open setting, shuts off compressor when you floor it, was mainly for safety, dont know but your problem sounds like something like this,could you have a bad reading from a sensor or ecm?or a throttle sensor, maybe you cannt find a direct link to throttle sensor, to electronic to a/c system, ?but you may have one?? my mk3s are ahu engines, so im fully electronic, and it blows,well some,,the ahu is rather sporty
added; do you happen to have an upshift sensor?
Reply #2July 25, 2015, 08:32:36 pm
« Reply #2 on: July 25, 2015, 08:32:36 pm »
if nothing else helps, look here, i dont know if it will help you, but it may
 https://forums.tdiclub.com/showthread.php?t=242699
Reply #3August 03, 2015, 01:56:55 pm
« Reply #3 on: August 03, 2015, 01:56:55 pm »
i mean you havent got back to us,, do by any chance have cruise control??any throttle sensor needs to be known,,it could be the problem,,or did you get it to work,,check charge?
Reply #4January 31, 2016, 10:17:42 am
WeekendMechanic
  • 78
« Reply #4 on: January 31, 2016, 10:17:42 am »
Hi sorry for the late reply no I did not find a solution to this all I did was jump the ac cut out relay
