Author Topic: WTB: Turbocharger for 1.6NA conversion  (Read 3642 times)
May 20, 2015, 01:14:26 pm
assforkr
« on: May 20, 2015, 01:14:26 pm »
Looking to replace P.O.s t3 with another turbocharger capable of 10-15PSI of boost, low exhaust restrictions and spool at lower end of the power band. Intent is stripped out daily mk1 rabbit for commuting and fun and not racing. Would love to be able to break the wheels loose but not power hungry. Running custom exhaust manifold with t3 flange and gasser intake
Current turbo has no shaftplay but probably has blown seal and wastegate flapper arm has been tacked closed and actuator removed so it's either new turbo or external wastegate and hope for the best.
Reply #1May 23, 2015, 05:00:22 pm
camboscams
  • 324
Re: WTB: Turbocharger for 1.6NA conversion
« Reply #1 on: May 23, 2015, 05:00:22 pm »
Don't know if you would be interested in a VNT, but i have one for sale with a functioning mechanical linkage system that is included. If you aren't running lots of fueling like i am you won't have the same issues i am with the vanes sticking. At least not as bad anyways. Here is the link PM if you are interested.
http://www.vwdiesel.net/forum/index.php/topic,35783.0.html
Thanks
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
