Author Topic: Gtd dieing  (Read 5549 times)
February 13, 2015, 03:14:24 am
Deanow24
  • 3
Gtd dieing
« on: February 13, 2015, 03:14:24 am »
After a short while driving my gtd cuts out and loses power?  Any suggestions
It's running a large FMIC pumps modified and 23psi of boost
Thanks for any suggestions
Reply #1February 13, 2015, 07:04:34 am
Re: Gtd dieing
« Reply #1 on: February 13, 2015, 07:04:34 am »
Fuel starvation is pretty much the only option.
How old is your filter?
Reply #2February 13, 2015, 09:16:26 am
Deanow24
  • 3
Re: Gtd dieing
« Reply #2 on: February 13, 2015, 09:16:26 am »
unsure of that! as only recently started using it after buying it, but im doing a complete service this weekend so hopefully that'll sort it
Reply #3February 13, 2015, 11:24:06 pm
Re: Gtd dieing
« Reply #3 on: February 13, 2015, 11:24:06 pm »
A clean filter first of all. If you're still having problems then things will get more interesting. Any chance the car has had WVO or other "alternative" fuel run through it?
Reply #4February 17, 2015, 07:56:11 am
jhax
  • 328
Re: Gtd dieing
« Reply #4 on: February 17, 2015, 07:56:11 am »
Also, check out the wire going to the electromagnet on the back of the fuel pump. I know mine gets loose at the connector sometimes causing it to cut out and not start on occasion.
Reply #5February 20, 2015, 12:10:00 pm
  • 2932
Re: Gtd dieing
« Reply #5 on: February 20, 2015, 12:10:00 pm »
install clear fuel lines.
