General Information
Troubleshooting
Gtd dieing
Topic: Gtd dieing (Read 5546 times)
February 13, 2015, 03:14:24 am
Deanow24
Newbie
Gtd dieing
February 13, 2015, 03:14:24 am »
After a short while driving my gtd cuts out and loses power? Any suggestions
It's running a large FMIC pumps modified and 23psi of boost
Thanks for any suggestions
February 13, 2015, 07:04:34 am
Re: Gtd dieing
February 13, 2015, 07:04:34 am »
Fuel starvation is pretty much the only option.
How old is your filter?
February 13, 2015, 09:16:26 am
Deanow24
Newbie
Re: Gtd dieing
February 13, 2015, 09:16:26 am »
Quote from: vanbcguy on February 13, 2015, 07:04:34 am
unsure of that! as only recently started using it after buying it, but im doing a complete service this weekend so hopefully that'll sort it
February 13, 2015, 11:24:06 pm
Re: Gtd dieing
February 13, 2015, 11:24:06 pm »
A clean filter first of all. If you're still having problems then things will get more interesting. Any chance the car has had WVO or other "alternative" fuel run through it?
February 17, 2015, 07:56:11 am
jhax
Re: Gtd dieing
February 17, 2015, 07:56:11 am »
Also, check out the wire going to the electromagnet on the back of the fuel pump. I know mine gets loose at the connector sometimes causing it to cut out and not start on occasion.
February 20, 2015, 12:10:00 pm
Re: Gtd dieing
February 20, 2015, 12:10:00 pm »
install clear fuel lines.
General Information
Troubleshooting
Gtd dieing
