Author Topic: 1.6 TD crank pulley question  (Read 2523 times)
January 20, 2015, 09:19:56 pm
idi-tracker
  • 12
    • American Speed Center
« on: January 20, 2015, 09:19:56 pm »
Collecting more parts for my 1.6 TD swap into my 4-dr Tracker,  The engine is a 1984 CY 1.6 TD, it came with a double crank pulley that resembles a harmonic balancer. (Elastomer ring between the hub and pulley).  I need to put power steering on it, so i found a complete pulley/bracket/ pump set up from a 1984 1.8 gti.  The crank pulley set up for the power steering is a inner and a outer pulley sandwiched together, and its solid, no elastomer center.  Will this be ok to swap over & run?
thanks
“Fighting for freedom is like screwing for virginity.”
Reply #1January 21, 2015, 05:50:12 am
Re: 1.6 TD crank pulley question
« Reply #1 on: January 21, 2015, 05:50:12 am »
yes
Reply #2January 22, 2015, 06:39:41 am
« Reply #2 on: January 22, 2015, 06:39:41 am »
The offset of the gasser crank pulleys is usually wrong due to the thin timing belt.
Reply #3January 22, 2015, 06:59:45 am
« Reply #3 on: January 22, 2015, 06:59:45 am »
He is correct but I think if you swap every pulley and bracket it will still function.
