Author Topic: Need to make Eco/k14 oil return line  (Read 2428 times)
January 18, 2015, 06:30:32 am
jlpst94
  • 72
« on: January 18, 2015, 06:30:32 am »
I searched for a thread with the fitting sizes and can't find anything.  Has anyone made a new return line with hydraulic fittings, etc?
Reply #1January 18, 2015, 12:04:46 pm
CODE4LS1
  • 73
Re: Need to make Eco/k14 oil return line
« Reply #1 on: January 18, 2015, 12:04:46 pm »
I purchased a k14 from a member here and he made a custom drain line using ss braided hose and -AN fittings to the oil pan.  He did reuse the male fitting and cut it off after the union on the turbo end.  I'll see if I can't snap some pics if it will help.
Oh yeah, seems to work, no leaks.
Reply #2January 18, 2015, 05:23:15 pm
jlpst94
  • 72
« Reply #2 on: January 18, 2015, 05:23:15 pm »
I saw a thread for this a while back and a member had fittings, part numbers, etc from a hydraulic website.  Of course I can't find it now
Reply #3January 20, 2015, 03:52:51 am
jlpst94
  • 72
« Reply #3 on: January 20, 2015, 03:52:51 am »
I found the thread but they were drilling the block.  I want to adapt to the fitting on the turbo pan
Reply #4January 20, 2015, 09:46:25 am
Rock3tman
  • 113
    prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
« Reply #4 on: January 20, 2015, 09:46:25 am »
IIRC, the oil pan on a 1.6TD takes a 16mm compression fitting on the tubing part.  After that, you can use barbed, -AN, JIC, or something you work up yourself to get upwards to the turbo oil drain.
Reply #5January 22, 2015, 05:24:36 am
jlpst94
  • 72
« Reply #5 on: January 22, 2015, 05:24:36 am »
Thanks, do you know the turbo fitting size?  It's a k14.
I don't have a shop near me or I would take it and have them match it up.
