Easiest way to put 1.6td head back on?
Topic: Easiest way to put 1.6td head back on? (Read 3564 times)
January 17, 2015, 07:52:57 am
jlpst94
January 17, 2015, 07:52:57 am »
The block is in the car an has head studs installed. Is it possible to put the head on with the manifold and turbo already on the head or should I put the head on and then bolt up the turbo, etc..
The manifold bolts were a pain in the ass to get off is why I'd like to try it with everything already mounted.
Also, is there no gasket between the turbo and manifold?
Thanks everyone
January 17, 2015, 08:27:51 am
Re: Easiest way to put 1.6td head back on?
January 17, 2015, 08:27:51 am »
Depends on the turbo, but yes you can put it on with everything there if it is one of the stock turbos that I have tried. No gasket from factory.
Round 2
January 17, 2015, 11:40:39 am
jlpst94
January 17, 2015, 11:40:39 am »
Ok thanks. It's a k14 from an ecodiesel so it sounds like I should be fine with it all mounted up.
January 17, 2015, 01:00:09 pm
January 17, 2015, 01:00:09 pm »
U will probably have to put the studs in after the head is on.
January 18, 2015, 06:01:05 am
jlpst94
January 18, 2015, 06:01:05 am »
Hmmm two different opinions now. Regardless of which way I do it, I'm not putting the exhaust and turbo on after the head is on. The bolts are too hard to get to
January 18, 2015, 12:06:38 pm
CODE4LS1
January 18, 2015, 12:06:38 pm »
I remove/replace with turbo, intake & exhaust intact. I removed the studs, placed the head and gasket on the block, then rethreaded the studs.
January 18, 2015, 03:08:53 pm
jlpst94
January 18, 2015, 03:08:53 pm »
yeah, this is the route i'm going. just putting the studs in after everything is sitting on the block
January 18, 2015, 03:23:17 pm
VW Smokr
January 18, 2015, 03:23:17 pm »
You can make head locating pins by cutting the heads and part of the shanks off a couple of old head bolts, then hacksaw a 1/16" deep slot into the protruding remnant of the shank. Loosely threaded into the block until 1/4"-1/2" protrudes above the deck surface, they can accurately locate & hold the head & gasket in place as you place it on the block & screw in the first 8 studs. A flat screwdriver & a magnet will fish them out of the block, allowing you to insert the final 2 studs.
J.R.
SoCal
January 18, 2015, 08:33:50 pm
air-cooled or diesel
January 18, 2015, 08:33:50 pm »
you work on the intake/exhaust when you pull head, easy to get too. it can be a real jungle gym to get to all ex/int while head is on the car. you need a tool for exhaust manifold spring clamps, among other tools needed to complete job.
January 19, 2015, 05:54:49 am
January 19, 2015, 05:54:49 am »
Been awhile, 2 years since the last one, but with the arp studs I think I put the front corners in and dropped the head on. I made the "dowels" our of the old head bolts, but I know I haven't used them since I got the arp studs.
Round 2
