Author Topic: Mk2 Hydro idi 1.6l engine and mk2 020 diesel tranny 5 speed - NJ  (Read 4729 times)
December 30, 2014, 09:15:48 am
FrankenDiesel
  • 59
« on: December 30, 2014, 09:15:48 am »
I have a later style hydro lifter 1.6 idi na diesel engine for sale. This was in my old daily driver, and drove very well. Mileage is unknown, but was getting a steady low 40s. The engine was very dry, with only a small seep at the valve cover (where the manifolds are) and a small tiny oil pan seep, very small. The rest of the block/head didn't have any leaks, and these concern areas are very cheap and did not even hit the ground (just wanted to let them know).
The ip is an NA pump, that is currently unbolted off the engine. If the engine is going into a mk2, it will need a mk2 pump bracket, but if into a mk1, I have a perfect pump bracket for it.
Right now, the engine is more or less a longblock. Its the head/block, various coolant flanges, IP. There aren't any manifolds, accessories, etc. (swapping the k14 setup to daily in the spring). Looking for 220$ picked up.
I also have a diesel coded 020 trans that would be best for a rebuild. All gears worked, but there were only two issues (that could have just been due to a linkage issue). First is, the shift lever did not have to be pushed down to engage 1st, it was engaged by a swift 1st gear range shift (got the car like that). And the second is, the car started to pop out of 5th gear going over 70+mph. Anything below that it stayed in gear. It could really just have been as simple as a linkage issue, but likewise I just wanted to mention it.
Im looking for 100$ picked up for the trans.
Or 250$ for tranny and longblock
Located in Flemington NJ
« Last Edit: January 01, 2015, 10:21:39 am by FrankenDiesel »
Reply #1December 31, 2014, 05:30:18 am
glayne
  • 2
Re: Mk2 Hydro idi 1.6l engine complete and mk2 020 diesel tranny 5 speed - NJ
« Reply #1 on: December 31, 2014, 05:30:18 am »
pm sent
Reply #2January 01, 2015, 10:22:29 am
FrankenDiesel
  • 59
Re: Mk2 Hydro idi 1.6l engine and mk2 020 diesel tranny 5 speed - NJ
« Reply #2 on: January 01, 2015, 10:22:29 am »
too cold to work outside swapping na manifolds/oil pan and oil housings off my daily to the spare motor. Selling as a stripped long block, price dropped.
Reply #3January 02, 2015, 09:36:04 am
glayne
  • 2
« Reply #3 on: January 02, 2015, 09:36:04 am »
pm sent lol
Reply #4January 04, 2015, 05:00:24 pm
diesel dub
  • 37
« Reply #4 on: January 04, 2015, 05:00:24 pm »
Wanna sell your k14?
Reply #5January 04, 2015, 08:57:44 pm
FrankenDiesel
  • 59
« Reply #5 on: January 04, 2015, 08:57:44 pm »
Not selling k14 sorry
Reply #6January 06, 2015, 08:34:57 am
VTPSD
  • 107
« Reply #6 on: January 06, 2015, 08:34:57 am »
I'm interested in the motor, you dont happen to ever travel towards vermont do you?
-1991 audi 90 quattro with AHU tdi, r520's holset he211
-1990 audi 90 quattro, holset turbo, 11 second quarter mile demon
Reply #7January 07, 2015, 08:54:47 am
FrankenDiesel
  • 59
« Reply #7 on: January 07, 2015, 08:54:47 am »
Emailed you.
The head is pending
