Author Topic: 4BT rebuilt pump.  (Read 11120 times)
December 09, 2014, 04:29:24 pm
One_punchmachinegun
  • 261
4BT rebuilt pump.
« on: December 09, 2014, 04:29:24 pm »
Hey guys I've got a 4BT rotary pump that I would like to put up for sale. I recently bought it with the intention to go mechanical with the TDI, but after thinking about it I've decided against it.
I would like to start at $400.00+shipping.
I will send pictures upon request.
Thanks much,
Timmothy
« Last Edit: November 03, 2015, 03:14:52 am by One_punchmachinegun »
的f anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #1January 01, 2015, 06:19:24 am
One_punchmachinegun
  • 261
Re: 4BT rebuilt pump.
« Reply #1 on: January 01, 2015, 06:19:24 am »
Bump
Reply #2January 17, 2015, 04:58:46 pm
One_punchmachinegun
  • 261
« Reply #2 on: January 17, 2015, 04:58:46 pm »
Bump.
Reply #3January 19, 2015, 10:34:07 pm
« Reply #3 on: January 19, 2015, 10:34:07 pm »
Posting pictures would really help with your sale. We don't know if this pump is a brand new Bosch rebuild still bagged and tagged or a greasy junkyard pull open to the elements.
Reply #4April 10, 2015, 03:44:25 pm
One_punchmachinegun
  • 261
« Reply #4 on: April 10, 2015, 03:44:25 pm »
I understand, and thank you. I will post pictures tomorrow.
Reply #5April 15, 2015, 06:35:17 am
One_punchmachinegun
  • 261
« Reply #5 on: April 15, 2015, 06:35:17 am »
Pictures are up.
Reply #6September 05, 2015, 12:51:38 pm
One_punchmachinegun
  • 261
« Reply #6 on: September 05, 2015, 12:51:38 pm »
Bump, I still have this.. make an offer.. 😶
Sent from my 0PJA2 using Tapatalk
Reply #7September 06, 2015, 05:26:09 am
« Reply #7 on: September 06, 2015, 05:26:09 am »
12mm pump right? just like the 6bt?
Reply #8September 06, 2015, 06:50:26 am
« Reply #8 on: September 06, 2015, 06:50:26 am »
The 4BT is 12mm.
Reply #9September 06, 2015, 03:50:37 pm
One_punchmachinegun
  • 261
« Reply #9 on: September 06, 2015, 03:50:37 pm »
Correct, there were some that came out not being 12mm after reading some so I will double check with some part numbers
Reply #10September 07, 2015, 07:25:27 am
One_punchmachinegun
  • 261
« Reply #10 on: September 07, 2015, 07:25:27 am »
The part number is 3917530LA , M060806020B,
Libby you might be able to help out and figure out if it's 12my or not.
Reply #11September 07, 2015, 07:34:54 am
« Reply #11 on: September 07, 2015, 07:34:54 am »
IMO, the easiest way to be certain of the plunger diameter is to remove the end cap and use calipers.  Torque it back to 55 ft-lbs.  For the socket you can get a 24mm 6pt socket and grind out three of the 6 flats or get a 24mm 12 pt and grind out 6 of the points - remove 2 and leave 2, etc...
Reply #12September 07, 2015, 08:43:11 am
One_punchmachinegun
  • 261
« Reply #12 on: September 07, 2015, 08:43:11 am »
Do you mean the remove the pump head.
Reply #13September 07, 2015, 09:02:40 am
« Reply #13 on: September 07, 2015, 09:02:40 am »
No, I mean remove the end plug (large nutlike thing with the triangular head).
Reply #14September 09, 2015, 06:40:31 pm
One_punchmachinegun
  • 261
« Reply #14 on: September 09, 2015, 06:40:31 pm »
Bump, I've not fabricated a socket yet. I did find that all 4BT pump 12mm. I have every intention of verifying it but it's very doubtful that it's not.
