Author Topic: Buy new turbo?  (Read 2776 times)
March 27, 2006, 06:24:30 am
turbotor
  • 50
Buy new turbo?
« on: March 27, 2006, 06:24:30 am »
My K14 is almost dead.....I need a new turbo, what to buy???
AAZ, FMIC, custom pump etc.
Can I use the old manifoild or do I need a custom one??
I see than most of the new turbos have water cooling, can it be driven without water??
I want as much power as the AAZ can handel.... :twisted:
Reply #1March 27, 2006, 06:28:53 am
Buy new turbo?
« Reply #1 on: March 27, 2006, 06:28:53 am »
buy a k24 it's bigger
Reply #2March 27, 2006, 06:52:32 am
turbotor
  • 50
Buy new turbo?
« Reply #2 on: March 27, 2006, 06:52:32 am »
Yea its bigger, but I was more into a new more modern fast spooling unit....and maybe even bigger than the K24.
Are there any difference in size of the K24 diesel turbos?
Reply #3March 27, 2006, 08:05:00 am
Buy new turbo?
« Reply #3 on: March 27, 2006, 08:05:00 am »
the k24it's bigger turbo in idi (xcuse i'm french and my english is small)
all k24 i's the same ,it's same turbo into audi s2(220/230ch 2.3l)
if you want install a modern turbo,the garett gtr25 ore 28 it's good idea.
Reply #4March 27, 2006, 09:36:58 am
fspGTD
  • 1529
Buy new turbo?
« Reply #4 on: March 27, 2006, 09:36:58 am »
Quote from: "golftd412000"
The only thing that is generally the same between all models of a turbocharger family (including the KKK K24 family) is the major diameter of the turbine wheel.  Almost always, other significant factors will vary between models in the family, such as various aspects of the compressor wheel and compressor housing design, the turbine wheel minor diameter, the turbine housing, including the A/R ratios.  Sometimes even the turbo bearing design and bearing housing can be different between models within the same turbocharger family.
The VW 1.6lTD turbo models have a special turbine housing with a unique, trapezoidal style turbine inlet flange and bolt pattern, for example.
Jake Russell
Reply #5March 27, 2006, 10:46:44 am
Buy new turbo?
« Reply #5 on: March 27, 2006, 10:46:44 am »
ok thank's for this lesson :D
