ASF, AON, ACN, ACL (8v) bolt to my 1.6l diesel?
Topic: ASF, AON, ACN, ACL (8v) bolt to my 1.6l diesel? (Read 2835 times)
March 26, 2006, 07:28:35 pm
sethyboy85
March 26, 2006, 07:28:35 pm »
just that simple would a ASF, AON, ACN, ACL (8v) tranny bolt to my diesel?
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
March 26, 2006, 08:03:20 pm
X@V
March 26, 2006, 08:03:20 pm »
They will bolt.
The ratios are different.
http://cars.vwsport.com/gears/index.html
March 27, 2006, 04:48:05 am
Maarten
March 27, 2006, 04:48:05 am »
bolt yes... but clutch/pressureplate/flywheel are needed too, the shaft is thicker and has more splines on it.
And the drivesaxles have 100mm CV joints instead of the 90mm, so you need those too.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
March 27, 2006, 05:23:27 am
sethyboy85
March 27, 2006, 05:23:27 am »
Quote from: "X@V"
They will bolt.
yes I know I want a longer geared tranny. clutch/flywheel are no big deal
both sites that I have seen are conflicting saying that a ACN and ASF are 90mm and 100mm (different years I guess)
does a 100mm use the same outer knuckle or would I need those as well off of a car.
March 27, 2006, 07:19:16 pm
wyldman
Authorized Vendor
March 27, 2006, 07:19:16 pm »
All you have to worry about is the flange size,the outer ends are the same.
It's not hard to swap flanges if you need to.
Auto Proformance Services - VW Diesel parts and service
(416)565-7282
March 27, 2006, 08:55:39 pm
dubCanuck1
March 27, 2006, 08:55:39 pm »
I've got two ACN's. One's a 100mm and the other's a 90mm. Go figure.
1992 Golf Diesel (2001 TDI powered by end of 2006)
[/b]
2001 VW Jetta TDI (Wife's)
http://www.canadubs.com
