TDI Engine -General Info
Reverse flow water pump Housing assy
Topic: Reverse flow water pump Housing assy (Read 12073 times)
July 15, 2014, 07:15:08 am
GEE-BEE
July 15, 2014, 07:15:08 am »
There stock in Europe
http://www.online-teile.com/audi/product_info.php?info=p333851006_028903141ap-halter.html&XTCsid=9e43721193ef35b707967e7e14c2844a
water pump are stock also
65.00
I ordered one and will advise fitment
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
July 15, 2014, 10:39:16 am
GEE-BEE
Pics
July 15, 2014, 10:39:16 am »
I have several pics if there is anybody that will post for others
[email protected]
Giles Pump OHC
MK1 JETTA DASH
July 15, 2014, 11:56:49 am
Diesel_Zuk
Re: Pics
July 15, 2014, 11:56:49 am »
What is the point of it exactly? I have never heard of it before.
July 15, 2014, 12:43:18 pm
Moderator
4549
Re: Reverse flow water pump Housing assy
July 15, 2014, 12:43:18 pm »
How's that work? Push Hot water into the bottom of the radiator instead of pull cold out? Maybe made to back flush the heater core?
Explain this one for us as we really do want to know. Purpose is?
July 15, 2014, 12:51:07 pm
July 15, 2014, 12:51:07 pm »
coolant flow is the same, the water pump just spins in the opposite direct.
July 15, 2014, 01:40:49 pm
GEE-BEE
July 15, 2014, 01:40:49 pm »
removing p/s from a ahu build with a/c
This is the way to run a complete serp and no v-belt to waterpump
http://www.vwdiesel.net/forum/index.php?topic=9599.30
GB
Giles Pump OHC
MK1 JETTA DASH
July 15, 2014, 04:48:50 pm
Moderator
4549
July 15, 2014, 04:48:50 pm »
Ahhh ha moment
July 15, 2014, 05:29:11 pm
July 15, 2014, 05:29:11 pm »
I'll reiterate what I mentioned in the other thread. I would personally rather have the water pump on the single v-belt and all the other accessories separate rather than have the water pump with all the other accessories. The water pump is the only essential belt driven item. Making its operation rely on the proper function of the serp belt, tensioner, A/C compressor and Alt means that if any of those items fail, you are dead in the water.
July 15, 2014, 07:54:27 pm
GEE-BEE
July 15, 2014, 07:54:27 pm »
With a 6pk belt, I will take my chances
Thanx Libby for your input....
Some people just have to be different....
I invented the first silicone/fiberglass aircraft valve cover gasket
The first were for just my aircraft, then the word got out....
Some models have 144 valve cover gaskets per aircrat ( B25 )and with these we have eliminated the leakage
Cheers to all here
GB
Giles Pump OHC
MK1 JETTA DASH
July 15, 2014, 10:18:53 pm
sdubfid
July 15, 2014, 10:18:53 pm »
do you make Volkswagen gaskets?
July 15, 2014, 10:44:35 pm
GEE-BEE
GASKETS
July 15, 2014, 10:44:35 pm »
Next will be exhaust gasket and the intake..
Intake silicone with fiberglass, no oil soak etc
The exhaust will be a very advanced material we use on aircraft exhaust, without the aircraft cost
Stay tuned, and dont touch that channel...
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #11
July 16, 2014, 08:12:13 am
Reply #11 on:
July 16, 2014, 08:12:13 am »
How about an AHU valve cover gasket??
Reply #12
July 16, 2014, 10:29:21 am
GEE-BEE
valve cover gasket aaz/ahu
Reply #12 on:
July 16, 2014, 10:29:21 am »
It's molded
I always drill and tap thr head and install the G60 valve cover/g60 vlave cover gasket
Giles Pump OHC
MK1 JETTA DASH
Reply #13
July 16, 2014, 04:43:54 pm
Re: Re: Re: valve cover gasket aaz/ahu
Reply #13 on:
July 16, 2014, 04:43:54 pm »
Quote from: GEE-BEE on July 16, 2014, 10:29:21 am
It's molded
That won't work with the AHU though, it has a wavy front. The AAZ works with the G60 cover but not the AHU /1Z.
Reply #14
July 16, 2014, 06:38:39 pm
GEE-BEE
GASKET AHU & AAZ
Reply #14 on:
July 16, 2014, 06:38:39 pm »
ahu
http://www.autohausaz.com/search/product.aspx?sid=slukq0blon0hwfndo4opot45&makeid=800026@VW&modelid=1360112@GOLF
TDI&year=1997&cid=20@Engine Parts, Seals %26 Gaskets&gid=10710@Valve Cover Gasket
EXHAUST AHU
http://www.autohausaz.com/search/product.aspx?sid=slukq0blon0hwfndo4opot45&makeid=800026@VW&modelid=1369661@JETTA
TDI&year=1997&cid=20@Engine Parts, Seals %26 Gaskets&gid=5400@Exhaust Manifold Gasket
INTAKE AHU
TDI&year=1997&cid=20@Engine Parts, Seals %26 Gaskets&gid=5424@Intake Manifold Gasket
aaz
http://www.autohausaz.com/search/product.aspx?sid=slukq0blon0hwfndo4opot45&makeid=800026@VW&modelid=1283958@JETTA
TDI&year=1996&cid=20@Engine Parts, Seals %26 Gaskets&gid=10710@Valve Cover Gasket
INTAKE AAZ
TDI&year=1996&cid=20@Engine Parts, Seals %26 Gaskets&gid=5424@Intake Manifold Gasket
EXHAUST AAZ
TDI&year=1996&cid=20@Engine Parts, Seals %26 Gaskets&gid=5400@Exhaust Manifold Gasket
Giles Pump OHC
MK1 JETTA DASH
