Author Topic: Airfilter Assy ( MK1 THRU MK4 ) Closed Box Assy  (Read 5450 times)
June 14, 2014, 09:18:43 am
GEE-BEE
  • 1604
« on: June 14, 2014, 09:18:43 am »
bare bones model
http://www.ebay.co.uk/itm/RAID-HP-1-4-TSI-Volkswagen-Eos-Induction-Intake-Air-Filter-Kit-Made-Germany-/390515779701?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5aec8de875#ht_2545wt_983
lots of extra parts in this kit
http://www.ebay.co.uk/itm/390515288287?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_2569wt_983
I was looking for options as for my build
I will have to make a 180 elbow from the turbo inlet retrun to the rh side of the Caddy MK1.
I will design one side of the elbows to the length of 14 long after the 180 with a inlet port for the crankcase breather
This kit will allow me to use a s/s joiner to the flex portion of the airbox duct
This will give me what Iam looking for as I dont want a open filter assy
« Last Edit: June 14, 2014, 09:22:47 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1June 17, 2014, 02:21:59 pm
wolf_walker
  • 1205
Re: Airfilter Assy ( MK1 THRU MK4 ) Closed Box Assy
« Reply #1 on: June 17, 2014, 02:21:59 pm »
Pretty slick, I might have gone that way instead of hacking the A2 TD airbox to fit my Caddy.
Mentat Text Two
Reply #2June 17, 2014, 06:15:28 pm
GEE-BEE
  • 1604
« Reply #2 on: June 17, 2014, 06:15:28 pm »
MKII snorkel found, I will make the new production with one or two ports and your color choice
I plan on mocking up a 180 2.25 alloy elbow to a 45 degee turn ans attach to this snorkel for a perfect intake for the GTB 2256 turbo for the
mark I or MKII install.....
Couple this with the Callaway turbo intercooler kit for a perfect bolt on install, no metal tubing for heatsoak
Let me know if any members are looking to do the same..
GB
« Last Edit: June 17, 2014, 06:20:47 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
