General Information
Troubleshooting
What the news car my engine / trans will fit
Topic: What the news car my engine / trans will fit (Read 7007 times)
June 02, 2014, 02:04:35 pm
Dean Erickson
June 02, 2014, 02:04:35 pm »
I have a 1.6 Diesel engine and transmission I would like to put in the newest vw car I can find. The engine and trans are out of a 1991 Jetta. I am thinking 1998 is as far as I can go. I am willing to change mounts if I am able to get into a newer Car.
June 02, 2014, 02:52:02 pm
Re:
June 02, 2014, 02:52:02 pm »
Any Mk3 will work great, just use the 2.0 mounts.
June 02, 2014, 03:08:45 pm
Dean Erickson
Re: What the news car my engine / trans will fit
June 02, 2014, 03:08:45 pm »
Not sure what is considered mk3 what years would that be? Would that include the new early bug?
June 02, 2014, 03:25:45 pm
Dean Erickson
June 02, 2014, 03:25:45 pm »
Just look it up on Google looks like 1993-1999
June 02, 2014, 03:45:18 pm
Dean Erickson
June 02, 2014, 03:45:18 pm »
Is the 1999.5 different
June 02, 2014, 04:34:23 pm
Re:
June 02, 2014, 04:34:23 pm »
The 99.5 is a Mk4, which uses a totally different type of engine mount system. There are no provisions on the 1.6 for the Mk4 platform mounts.
And yes, a Mk3 is 1993-1999. If you are going that route an AAZ car (Canada only) is a straight drop in, absolutely everything is the same. If you can't find one of those the ABA cars are your next best bet. They will have the correct clutch and gear shift linkages already.
June 03, 2014, 12:31:09 pm
Dean Erickson
June 03, 2014, 12:31:09 pm »
What about the 1998 bug is that a mk4 ? That would be ideal, I have my eye on one that has been sitting out behind a guys garage for a long time.
June 04, 2014, 12:33:21 pm
June 04, 2014, 12:33:21 pm »
The Beetle is a Mk4. The Mk4 platform was designed specifically for the Beetle, so it was the first car released using all the new stuff.
June 04, 2014, 01:03:30 pm
Dean Erickson
June 04, 2014, 01:03:30 pm »
Ok thanks for the info
June 05, 2014, 12:03:55 pm
June 05, 2014, 12:03:55 pm »
Just rember it will fail all emissions... Nothing newer then 92 in usa... Can be idi or tdi-m... Then 96 goes to tdi e...
June 05, 2014, 01:24:01 pm
srgtlord
June 05, 2014, 01:24:01 pm »
Depends n where you live. In massachusetts there are no emission tests on vehicles 1997 and older
Reply #11
June 12, 2014, 02:03:56 am
Dean Erickson
Reply #11 on:
June 12, 2014, 02:03:56 am »
No testing done in Michigan
Reply #12
June 22, 2014, 02:55:58 pm
Dean Erickson
Reply #12 on:
June 22, 2014, 02:55:58 pm »
I have one more question are the older passers mk 3 cars? I can't find any info on them.
Reply #13
June 22, 2014, 03:03:22 pm
Re:
Reply #13 on:
June 22, 2014, 03:03:22 pm »
The B4 Passats are mechanically very similar to the Mk3 (or A3 as they are also called). I don't know the cutoff years for the B4 but basically anything you can do with a Mk3 you can do with a B4.
Reply #14
June 22, 2014, 05:36:32 pm
Dean Erickson
Reply #14 on:
June 22, 2014, 05:36:32 pm »
Ok thanks I am going to look for a early Passat and see what the engine bay looks like. I have a 1.6 with a ff transmission allready to transplant into a newer car. Looking right now on CL for a deal on a car with a blow engine or transmission. I am hoping to find something for around 700-1000. I put a Diesel engine in a 1985 gas Jetta so I am sure I can swap to a newer VW. Thanks
General Information
Troubleshooting
